Leak
Old Oct 23, 2002 | 09:17 AM
Tee Jay's Avatar
Default Leak
Does your CRX leak where the hatch is???
Is so, how do you fix it?
Old Oct 23, 2002 | 09:18 AM
Tee Jay's Avatar
Default Re: Leak (CrX_HF)
One more thing, how do you change your avatar?
I can't seem to change mine. (Smiley face =/ )
Old Oct 23, 2002 | 11:40 AM
Louie B.'s Avatar
you're still a trial user, you can't change the avatar until it says "honda tech member" under your name
Old Oct 23, 2002 | 09:49 PM
neutron91's Avatar
Default Re: Leak (thumpu77)
mine didnt leak until i gutted the interior... now it leaks where my tailights are... im guessing it leaks cause the plastic cover isnt over the tail lights anymore and it allows a slight gap for water to sneak into... its blown a few bulbs already so everytime it rains i have to check my tail lights... ive heard of putting silicone around where the tail lights are... could anyone whos done this tell me exactly how they did it?
Old Oct 24, 2002 | 02:15 PM
type Gendy's Avatar
Default Re: Leak (neutron89)
The leak shouldnt have anything to do with removing the interior plastic. I put silicone/putty on my taillight to stop it from leaking. I did the passenger side only to see if it made a difference, and I dont think there is any water coming in on that side now, just have to find the time to do the driver side.
What I did:
Remove the tailights, clean all the dirt and dust off on the car, tail light, and everything. Pull off the foam gasket from the tailight. Try to clean the gasket up too if its got dirt on it. Spread the silicone in between the gasket/ light and gasket/car. Apply the silicone on both sides, then put the Taillight back in. This should slow it down, or stop it. It should be easier to tell if it still leaks because u have no interior, its hard to tell where the water is coming from with all the plastic still intact
Old Oct 24, 2002 | 02:21 PM
type Gendy's Avatar
Default Re: Leak (shoddy116)
Hope that helps....
I have the same leak where the hatch pistons connect to the car, i havent figured them out yet... I have heard that it could have something to do with your sunroof drain tubes?? If you have one...idk
Old Oct 24, 2002 | 02:23 PM
SiRex91's Avatar
Mine has a slight leak near where the roof panel meets the hatch, but it only leaks if my car sits in absolute pouring rain all night.
Old Oct 24, 2002 | 02:25 PM
Hcivic88's Avatar
yeah, i did the silicone thing too, i heard thats one of the main places for a 4th gen to leak, and that i needed new gaskets, but i heard silicone works too, so i tried it, and no more leak that i've noticed
Old Oct 24, 2002 | 02:41 PM
Rob!'s Avatar
Default Re: Leak (Hcivic88)
mine doesnt leak but my guess would be find out whereyour leaking 1st
Old Oct 24, 2002 | 03:14 PM
Tee Jay's Avatar
I don't have a sun-roof.....
And it drips off the hatch pistons and onto both of my rear speakers
SprayedPaint
Jan 9, 2016 04:57 PM
vega_ROCKS
Dec 18, 2008 12:19 AM
oMek
Apr 19, 2004 07:29 PM
TXGirl
Jul 7, 2003 02:48 PM
