Aftermarket Sway Bars for 98 Civic DX Hatch
98 Civic Hatchback DX. I have no OEM sway bars and am looking at factory kits. I'm wondering how these kits attach the front bar to lower control arms with no factory mount provisions... so if you have any kits like Suspension Tech, Eibach etc, can you post pics of how it's attached?
Or should I be looking into getting some LCA's from an EX?
TIA
TIA
Get the front lca from an ex and you should be good to go. Unless u want the ctr or si 26mm bar up front then get the si lca and shock forks( with pinch fork bolt). I am also pretty sure you can use the ex lca with diff endlinks to fit the 26mm up front.
http://www.d-series.org/forums/suspe...tons-info.html
Searching using google and use honda-tech in the string.
This has been covered many times.
Frank the midget will come shave off your eyebrows if you post without searching.
I will get the ex LCA's and probably go with a Blox front 26mm bar.
For the Rear sway bar... what does everyone thing about Whiteline?
http://www.ebay.com/itm/370802981087...84.m1438.l2649
Or could I make this fit my 98 EK??
http://www.velocityshop.com/product/...egra_1221.html
We dont ... its off of ebay. non name brands.. you get what you pay for.
I can see those cheesy end links bending.
the subframe brace isnt too bad.
Yeah, I figured I would be running different end links... but Whiteline is out of Australia.. not really a no name brand.
I don't want to pop for and ASR setup.. but it might be my only option here..
whiteline is not ebay brand they just mostly do Subaru parts . and you can use a integra bar the subframe brackets are shaped different so you need a spacer or one for an em1
Love how people see it in eBay and from that fact hate like no tomorrow. Aem, asr, Pwjdm, dc sports, bwr and a huge lot of others are on eBay.
If you loved me, you'd all sell me your magic cards to me today
jewpont
10
Dec 25, 2007 04:27 PM
MugenManR
13
Feb 22, 2007 09:02 PM
