Temp Gauge Not Reading Correct
Old May 6, 2013 | 10:56 AM
GeneBEllis's Avatar
Default Temp Gauge Not Reading Correct
Hey guys it seems that my temp gauge would go all the way to hot but the engine is fine, does anyone know what could be wrong?
Old May 6, 2013 | 04:36 PM
DirtyDA9's Avatar
Default Re: Temp Gauge Not Reading Correct
Ect sending unit.
Old May 6, 2013 | 05:07 PM
fcm's Avatar
fcm
Old Fart
Ditto that,^^^ it is the first thing I would check. 94
Old May 6, 2013 | 05:09 PM
ATISTANG's Avatar
are you sure your engine isnt over heating?
Old May 6, 2013 | 09:10 PM
el crapitan's Avatar
the wiring could also be shorting to ground. i believe with the sender, when grounded, the needle goes pegged. and given it's location, the wiring insulation is extremely susceptible to becoming brittle and cracking, leaving the strands exposed
Old May 7, 2013 | 07:01 AM
sleepyaccord96's Avatar
if it is a 92 to 96 prelude then you should look into the actual dash gauge cluster assembly. the fuel gauge and temp gauge assemblies tend to tear up and the temp will read hot like it is overheating although nothing is wrong and temp is at normal.
Dmascarenasp
Honda Civic (2001 - 2005)
Mar 14, 2016 11:15 AM
97grnrs
Feb 17, 2007 07:06 AM
HondaTeg95
Feb 15, 2006 05:24 PM
Boofster
Dec 6, 2004 03:18 PM
