Lighting HID/Xenon kits, Retrofits and Associated Topics
Footwell lighting with domelight
Old May 2, 2013 | 04:08 AM
chillerice's Avatar
Default Footwell lighting with domelight
Sup people.
First off let me just add that I'm not trying to rice out my car .
I understand alot of guys do LED strips in the footwell on a switch in their cars for that cool show look. I'm not going for that.
I'm curious if I can hook up two to my door switch/domelight wires. And if I do need a relay;how do I wire it up? 1998 civic ex coupe.
If it's not safe I can always opt for the switch type but I just kinda wanted a clean install,without looking riced out with a toggle switch imitating NOS or some other crap. SMH!!!
Old May 2, 2013 | 04:32 PM
chillerice's Avatar
Default Re: Footwell lighting with domelight
Nobody???
Old May 2, 2013 | 05:47 PM
TunerN00b's Avatar
Originally Posted by chillerice
Sup people.
You'll need to better explain what it is your asking, and wanting to do.
Also, if you need instruction on how to use a standard automotive relay (which are available all over the net), then this sort of project is probably not for you.
As to whether or not you need one, that depends entirely on the capacity of the circuit you're trying to add on to, and the additional draw of whatever else you're adding. In other words, no one can answer for you without a lot more information.
Old May 2, 2013 | 08:14 PM
chillerice's Avatar
All I'm generally asking is can I add two LED strips to my domelight/door circuit without blowing the fuse?
And if I could end up blowing the fuse; do I need to use a relay and wire the LED strip like a alarm domelight supervision?
Old May 3, 2013 | 10:36 AM
TunerN00b's Avatar
And again, that isn't answerable. It depends on the existing load on the circuit that will be kept, the additional load of the new strips, and the existing fuse. You could be adding a 5A draw to a 15A capable line with only 5A currently in use, which would be fine. You could also be adding a 12A draw to a 10A line, which will blow the fuse.
Seriously, don't ask on here, go get the numbers for the new LEDs you wish to use, measure the existing power draw of the circuit, then compare the combined total to the fuse.
And don't replace the fuse with a larger one, as you'll risk burning wires before the larger fuse pops, rendering it useless. Do it properly with a relay and additional inline fuse.
Yes, if you exceed the fuse's capability, you'll need a relay, an additional inline fuse sized appropriately, and a direct line to the battery.
JDM_d15b_eg8
Dec 26, 2006 05:17 AM
Dc2 Powered
Oct 6, 2004 07:01 AM
Simple
13
Jan 10, 2004 07:57 AM
asianspeed
Audio / Security / Video
Mar 10, 2003 02:21 PM
