92 DA cooling system problems
I have a 92 LS, I just recently installed a new thermostat because my lower hose wasn't getting hot and my temp Hague was fluctuating. I replaced it and now my gauge works fine.but the lower hose will still not get hot. This.morning I check to see if there was air in the system and I opened the bleeder valve, coolant came out when I had the cap.off but when I put the cap.on and let it warm up again the nothing came out.of the bleeder valve. Hose will still not get.hot. Any ideas what this could be? A faulty thermostat? the fans won't kick on also but haven't tested to see if it a bad motor yet.
simplypinoyy
23
Aug 6, 2004 03:06 PM
