How to fix broekn brake booster fitting
Old Apr 30, 2013 | 11:42 PM
metalslug's Avatar
Default How to fix broekn brake booster fitting
The fitting on the intake manifold is broken, how do i exactly fix his? Any ideas and suggestions would greatly be appreciated. Thanks.
Old May 1, 2013 | 12:18 AM
jbpnoman's Avatar
Default Re: How to fix broekn brake booster fitting
Do you want to properly fix it, or ghetto rig it?
If you want to properly fix it, you have two options. Option A, replace the intake manifold. Option B, find a way to remove the part of the fitting that is stuck in the IM, and find a replacement. Good luck on that - They aren't sold on their own.
If you want to ghetto rig it, find a way to fully remove the part of the fitting stuck in the IM, and then find some pipe fitting to screw in there.
Old May 1, 2013 | 09:59 PM
metalslug's Avatar
thanks, ill see which is the easiest route to take from those you listed....
Old May 2, 2013 | 02:27 AM
Texas4door's Avatar
Could the OP weld/braze it back together?
Old May 2, 2013 | 07:26 AM
strategy400's Avatar
Epoxy if you really want to slum it.
Old May 2, 2013 | 08:15 AM
sleepyaccord96's Avatar
when i got my h22a swaps from hmotors ( i bought 2 jdm h22a swaps one was lsd and one was not) anyways, both had those fitting broken off/cracked. i simply CAREFULLY removed them and pushed new ones in that were free courtesy of steve at hmo.
Old May 2, 2013 | 08:58 AM
The key here is not to do anything that could result in foreign debris being sucked into the engine.
Thank you, thank you (graciously accepts Capt. Obvious award and sets it on the mantle with the rest).
Old May 4, 2013 | 09:32 AM
metalslug's Avatar
I have other manifolds, i will try and remove, any idea on how?
Bquinhas
Jun 11, 2008 10:52 AM
greddyboy
May 11, 2006 12:53 AM
Exempt
Mar 24, 2005 11:33 AM
DeadLock23
Mar 19, 2004 02:57 PM
