What is this called, and where can I get it?
Old Mar 23, 2005 | 11:12 AM
Exempt's Avatar
Default What is this called, and where can I get it?
When I got my engine in (JDM D15B VTEC), this peice was damaged from transporting it... Its the small pipe that goes from the intake mani, to the brake booster... So I asked around, and ppl said I could remove it... Which I finally figured out how to remove it from the Intake Manifold, the only prob now is, I dont know where to get another one from, or what its even called...
Thanks in advance!
Old Mar 23, 2005 | 11:46 AM
tgreaves's Avatar
Default Re: What is this called, and where can I get it? (Exempt)
Its a vacuum fitting.. I would just remove it and tap the hole and put another fitting there from a parts store..
Old Mar 23, 2005 | 11:56 AM
Exempt's Avatar
So any parts store should know what it is, and sell them?
Old Mar 23, 2005 | 12:00 PM
msmotorsports's Avatar
Default Re: (Exempt)
Just go to Honda and pick one up. Those really aren't universal so parts stores most likely wont have it. You'll need that vaccum port for your brake booster so make sure you get teh correct one. If Honda doesnt have it you can tap the hole with pipe thread and get a brass fitting for it.
Exempt's Avatar
K, thanks guys!
Old Mar 23, 2005 | 12:05 PM
tgreaves's Avatar
Default Re: (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">If Honda doesnt have it you can tap the hole with pipe thread and get a brass fitting for it.</TD></TR></TABLE>
This is what I was saying, I guess I didnt explain it well enough..
Old Mar 23, 2005 | 04:32 PM
dfoxengr's Avatar
Default Re: (tgreaves)
drill/tap it and run a 1/8npt to 1/4 barb fitting on there
Old Mar 23, 2005 | 06:57 PM
SOHCmaster's Avatar
Default Re: (hybridvteceg)
I think its bigger than 1/8 to 1/4.. More like 3/8 or 6AN to barb
Old Mar 23, 2005 | 07:36 PM
dfoxengr's Avatar
Default Re: (PK SPEED)
first off a 3/8 np is about 3/4 " in dia. AN fittings are a compression fitting also
1/8 npt and 1/4 barb is the perfect size for that thing on the manifold
Old Mar 24, 2005 | 05:50 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">first off a 3/8 np is about 3/4 " in dia. AN fittings are a compression fitting also
1/8 npt and 1/4 barb is the perfect size for that thing on the manifold</TD></TR></TABLE>
I dont have the hole in front of me but I would guess that it is a little too big to thread it for 1/8npt.. If so a 1/4npt will work..
tgreaves's Avatar
Also enlighten me, how did you remove it from the manifold.. I have a few of them on my B16 manifold that I dont need and would like to remove/plug them..
Old Mar 24, 2005 | 06:41 AM
dfoxengr's Avatar
Default Re: What is this called, and where can I get it? (tgreaves)
a 1/8 pipe tap OD is about 3/8" so 1/8 should be perfect.
just becasue it says 1/8 doesnt mean the od is 1/8, lol
and 1/4npt is alittle over 1/2 inch OD
i dont mean to argue but ive been working with and selling fittings for over a year now and im pretty sure i know what im talking about
Old Mar 24, 2005 | 11:33 AM
Exempt's Avatar
Thanks for the responses guys! Ill try them out!
So this is what I need?
http://www.coleparmer.com/cata...34700
And then just use a tap tool and tap it out to 1/8"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Also enlighten me, how did you remove it from the manifold.. I have a few of them on my B16 manifold that I dont need and would like to remove/plug them..</TD></TR></TABLE>
I tried a few different ways, but the way that worked, I took a long, sturdy, flat head screw driver and set it between the manifold and the pipe, there was little lip on the pipe (u can kinda see it in the pics), and hit the top of the screw driver with a hammer... Each time I did it, it came out more, took about 4 good wacks... If u dont need the fitting then this should be fine... Just careful not to damage the manifold too much... I damaged the fitting, but it was already broken so it didnt matter...
Modified by Exempt at 12:56 PM 3/24/2005
metalslug
May 4, 2013 09:32 AM
will46r
Feb 8, 2012 11:44 AM
ALIŅOCIVIC
Jun 30, 2010 07:17 PM
dub204
Jul 21, 2006 11:12 PM
JohnnyEF
Feb 7, 2003 07:44 PM
