wot cel then limp mode Help anyone
Okay saturday I had my car tuned turbo h22 hatch freshly built motor 9.1 eagle rods running hondata s300 car was perfect on dyno and it runs great normal driving but as soon as I hit wide open throttle cel comes on and limp mode well can't even drive it mode if I shut it down turn it back on its like it never happened!!! Until wot I checked my dizzy coil and icm are good. Oh one more thing I'm only running 9pounds took off the boost controller when it started acting up
Almost forgot I'm using hondata 4bar lean protection is disabled full boost wideband gauge reads 12.5 kinda lean with my meth kit turned down got afr to read 11.5 weird thing is it was tuned to 11.5 full throttle 14.7 normal professional tune also
Sounds to me like your tps sensor is ready wrong wot voltage. I am willing to bet you are hitting a full 5.0v at wot tripping light and limp mode
Minimum reading in hondata is -0.14 closed throttle ....wot is 99.98 however tps checking it manually was off 0.30 closed throttle fixed to 0.50 closed throttle gonna take it for rip let u no how the adjustment is
