Disconnected hose. Where is your home?
Old Apr 23, 2013 | 02:49 PM
bromas203's Avatar
Default Disconnected hose. Where is your home?
Hello hello
I have discovered a Y tube with the two end parts loose, but plugged up. The beginning of the tube is joined to the tube running from the very right hole in the intake manifold to the littl canister on the the very right of the fuel rail, not sure what its called. I need help figuring out if these need to be connected or can be deleted.
I will post pictures when I come back from work at around 9est.
I'm running a d15b if that helps.
Old Apr 23, 2013 | 03:04 PM
PunchedGuava's Avatar
Default Re: Disconnected hose. Where is your home?
I'm assuming it connects to the charcoal canister? Those aren't needed really. It's more of an emissions gadget. Is your CEL on?
If I'm guessing right, it should be area D in the picture below..?
Old Apr 23, 2013 | 03:13 PM
crazyhouse2011's Avatar
Hey please tell me what each labeled area is.
Old Apr 23, 2013 | 03:26 PM
A = Opening for A/C lines to enter cabin
B = Opening for coolant lines to enter cabin
C = Fuel filter
D = Charcoal canister
E = Brake booster vacuum line
F = (2) EGR valves (only found in D15Z1 / VX bays)
G = Fuel return line
From http://www.k20a.org/forum/showthread.php?t=24248
Old Apr 23, 2013 | 03:51 PM
bromas203's Avatar
This is the tube in question. See the silver tube? Im talking about the tube coming out of the middle of it.
image hosting 5mb
Here is a pick of the ends.
upload a picture
@Punchedguava, My charcoal canister has tubes already connect to it. The previous owner had the car turbo'd so im not sure if these are just residual lines left around after he took it off?
Old Apr 23, 2013 | 03:52 PM
bromas203's Avatar
didnt realize when i took the pic but u can actually see the charcoal canister in the second picture upper right.
Old Apr 23, 2013 | 03:54 PM
B_Swapped93's Avatar
they look like they go to the charcoal canister. either plug them in or just leave them capped.
but try looking threw here https://honda-tech.com/forums/showth...2483147&page=2
Old Apr 23, 2013 | 04:39 PM
EsotericImage's Avatar
Retired Moderator
there shouldnt be a Tee in the FPR line
Old Apr 23, 2013 | 04:45 PM
****, i just noticed the FPR^
OP get ride of the "T". It's supposed to go straight from the ITM to the FPR.
Old Apr 23, 2013 | 06:19 PM
Retired Moderator
Looks like this was a boosted engine or something used the line as a vac reference..
Is this a newly swapped in engine? Or was car bought like this recently?
Might have some internal injuries if it has a forced fed past.
Old Apr 24, 2013 | 06:12 AM
bromas203's Avatar
So i should remove the black tube intersecting the silver tube running from the IMF to the FPR?
I was told from a mechanic that the engine was turbo'd since the "oil pan is tapped", also has a catch can set up. I bought it with this swap 4 months ago, the owner told me the motor had 80k on it, chassis had 139k. After hearing that it used to be turbo'd ive deffinitly been worried about reliability issues, not knowing how the last owner drove it.
I've also just noticed a new grinding noise coming from the trans when im at full stop, But maybe i should start a new thread for that?
Old Apr 24, 2013 | 07:26 PM
Allboost18b's Avatar
I'd put a lot of money thats for your Vaccum log, someone split it from your Intake line that controls your vaccum to your fuel return valve.
You don;'t need a vac log if youre back to all motor. Take that T out.
Converting from turbo to all motor = stock exhaust, reverting the Basemap to stock in the ECU, Vaccum log deletion, plugging off the Oil pan tap, plugging off the oil line feed...
Check those major things as well...
The grinding noise could be a bad clutch throw out bearing... make sure the tranny was assembled right. if there's grinding something's not right.... may even be the stock clutch was too tight / fly wheel bolts arent tight enough/ loose pressure plate... Tons of things man.
Old Apr 25, 2013 | 07:09 AM
bromas203's Avatar
ok thanks, tube has been removed. I have been driving the car many many miles each day since im a delivery driver and it has not failed me once. would i have realized some major issues if most of the "converting back to N/A" was not done? the car runs really smooth engine wise, only thing that seems to be a little worn is the tranny.
Would not having a stock exhaust cause a loss of power/efficiency? Tips of my exhaust says apexi but it might just be the muffler?
Old Apr 25, 2013 | 07:26 AM
kyden's Avatar
what makes you think they didn't completely remove the turbo setup?
Old Apr 26, 2013 | 07:17 AM
bromas203's Avatar
it seems to me that they DID remove the whole turbo set up, set everything back to working N/a.
Baby99EX
20
Apr 2, 2017 02:17 PM
VeganEJ8
Jul 14, 2013 12:16 PM
All-Motor-Junkie
Feb 16, 2007 09:25 PM
OMG naD16 lol
Nov 23, 2006 03:28 AM
the0ne
Dec 10, 2004 06:20 PM
