oil feeding from oil pump
Guest
Posts: n/a
i know Z10 sells those fittings for B and D series engine that go into the back of the oil pump, i've got one for the external oil line on my LS/VTEC, but, can you use a line from there asthe oil feed line on a turbo on an H series, if so, i am going to make a fitting, if not i will just T off the sending unit i guess, and hope it doesn't break
Uhm, were you to remove the plug then no oil would go to the engine (it would all go on the ground). So yes, there is enough oil to feed the turbo.
isn't that fittin really really close to the alternator. so close that the hose or line is going to kink or take a sharp turn so it wont touch the alternator. at lease from the looks of it on my d16a. any expericences?
