Ok I Burned Up My #3 Rings so I'm smoking Bad -Please Help W/ New Build-
This sunday i ran 18lbs of boost on my stock block and now the the rings on my number 3 piston ar bad and i'm smoking bad
What should I use to build my block
I thinking
Je 8.5:1 Pistons
Eagle Rods
Darton Sleaves
Please Tell me what I should use ?
And best place to buy my parts
I thinking
Je 8.5:1 Pistons
Eagle Rods
Darton Sleaves
Re: Ok I Burned Up My #3 Rings so I'm smoking Bad -Please Help W/ New Build- (b16sir1)
hrmm good start, id go w/ these:
Je or endyn 9.1:1 Pistons
Eagle Rods
Id go w/ GE sleeves
arp head studs
acl bearings
then of course you will want a new water and oil pump, new timing belt
etc
Talk to Viren about GE sleeves
Talk to DamonBoost (he is having a groupbuy) about JE pistons and Eagle rods
[Modified by Mase, 10:45 PM 10/22/2002]
Eagle Rods
Id go w/ GE sleeves
arp head studs
acl bearings
etc
Re: Ok I Burned Up My #3 Rings so I'm smoking Bad -Please Help W/ New Build- (Mase)
Eagle Rods
Id go w/ GE sleeves
arp head studs
acl bearings
Eagle Rods
Id go w/ GE sleeves
arp head studs
acl bearings
Don't get that 8.5:1 CR crap... it all hype, you will have no low end Tq... I ran 8.97:1 and the tq was still kinda crappy below boost. If you only intend to boost about 18psi, go with something between 9 and 9.5 or so. 9.2 is stock CR on an LS, so that would be decent tq low end.
Eagle rods are GREAT for the price, and with forged pistons, you won't necessarily need to go sleeved for 18 psi, but if you do, you can opt for a larger bore before you buy the pistons.
Have a block guard properly installed and welded in before building and you will prolly want to consider upgrading to a Fluidyne radiator and maybe even some FAL fans.
Do you have an I/C that can keep the temps down at that boost pressure ?
X2
Re: Ok I Burned Up My #3 Rings so I'm smoking Bad -Please Help W/ New Build- (X2BOARD)
I'm wanting to run 18lbs on the street and 22lbs on the track
so i don't need 8.5:1 pistons.
All i'm looking for is 450 whp
i have the mavrev 20x8x3" intercooler
Wiseco 8.8:1 84.5mm Pistons
Eagle Rods
84mm Darton Sleeves
ARP head studs
ACL bearings
Talk to 93LSivic, he gave me a good deal on my parts.
207hondaguy
01-21-2012 07:29 PM
