92 civic h22 code diagnosis question
Old Apr 20, 2013 | 07:16 AM
ReaperMan's Avatar
Default 92 civic h22 code diagnosis question
its a 92 hatch h22a swap obd1 engine and harness p72 ecu, mods headers and straight exhaust, swapped out intake manifold few days ago with a skunk 2 pro series intake, along with a 70mm matching throttlebody, fired it up and it's idling very low rough idle what semms to be a misfire greyish smoke running PIG rich, firing order correct only things swapped to the intake were tps, map and iacv. ran the codes two long flashes back to back no pause between them which i would assume is code 2?
Old Apr 20, 2013 | 07:20 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 92 civic h22 code diagnosis question
"swapped out intake manifold few days ago with a skunk 2 pro series intake"
Here's your real problem. Is it tuned for these mods?
Assuming the P72 is also OBD1 I'm having a hard time understanding how it's throwing out a code for a second O2 sensor.
Old Apr 20, 2013 | 07:35 AM
ReaperMan's Avatar
no ecu is not tuned yet, but ive had friends do this swap with NO IDLE PROBLEMS OR RUNNING THAT RICH!!! i understand im suppose to get a tune im getting a s300 shipped already just waiting on that, and yes an obd1 p72 *facepalm* a shop did this swap *facepalm* i know i thought it was an o2 but then realized it says second o2 the ecu says dc2 on it and sticker says p72 which has me puzzled. so two LONG FLASHES BACK TO BACK is code 2? and it actually doesn't idle i have to rev it to 1k and SLOWLY bring it down for it to stay on but it idle so low that the engine knocks so i try to keep the rpm's up,
Old Apr 20, 2013 | 07:37 AM
The Grumpiest
Unless it's a code #22 somehow. 22 VTEC pressure valve.
I swear I'm sure you're supposed to keep the harness that comes in the car when doing these things. But I'm not a swap expert so I don't know.
Old Apr 20, 2013 | 07:42 AM
ReaperMan's Avatar
hahaha yeah i think its the stock civic harness even if it is code 22 i don't think it would run like this, its a jdm h22a if it helps any
Old Apr 21, 2013 | 02:36 PM
ReaperMan's Avatar
update: put the stock h22a intake manifold back on and idled perfect. guess the p72 can't run those upgrades stock while the p13 can. we are now going to take it to bisimoto get hondata on the p72 bolt on the the skunk2 pro series intake and dyno. we are also going to drop in an lsd package with ls 5th gear, has stage 3 act clutch along with a 8 fidanza flywheel
Old Apr 21, 2013 | 02:49 PM
The Grumpiest
I guess that would make sense. The P13 is the ECU for the H22 in the first place isn't it (I didn't feel like looking)?
Old Apr 21, 2013 | 03:35 PM
nub's Avatar
nub
Long CEL blinks have a value of 10, so 2 long blnks would be 20.
Old Apr 21, 2013 | 04:20 PM
The Grumpiest
20 is the code for the ELD.
blackwagon
Nov 16, 2010 07:15 AM
nathanjohnson2009
Apr 24, 2010 11:26 AM
2000siturboR
Jan 7, 2009 07:33 AM
skate_volcom2006
10
Aug 28, 2008 12:53 PM
y49crxsi
Sep 10, 2003 04:24 PM
