Compression Test: 20 Psi below cylinder #3
Old Apr 20, 2013 | 04:40 AM
Team_Coast978's Avatar
Default Compression Test: 20 Psi below cylinder #3
Did rings on cylinder #2, swapped heads and now I have 20psi lower on cylinder #3. My compression was fine before on that cylinder ....
- All other cylinders between 165-178 .. #3 is about 155
- Do I need a valve adjustment maybe ? Or is it build up on valves ? (Never changed valves, just cleaned them up a bit)
- Car sat a while, this is a long shot, but could it be a sticky ring ?
Old Apr 22, 2013 | 09:48 AM
Rtype16's Avatar
Default Re: Compression Test: 20 Psi below cylinder #3
Did you do a valve adjustment when you put on the new head? Try that first.
Old Jun 10, 2013 | 10:58 AM
VegasInvasion's Avatar
I'm Huge In Japan
or you may have a head gasket leak. pretty common. copper spray it.
Brandon Peters
Oct 18, 2015 05:40 PM
Team_Coast978
Aug 24, 2013 09:31 PM
zerovandez
Oct 3, 2011 05:38 PM
egjack
Dec 2, 2010 06:43 AM
teefunk01
Nov 14, 2005 07:57 PM
