Compression Test: 20 Psi below cylinder #3
Old Apr 20, 2013 | 11:49 AM
Team_Coast978's Avatar
Default Compression Test: 20 Psi below cylinder #3
Did rings on cylinder #2, swapped heads and now I have 20psi lower on cylinder #3. My compression was fine before on that cylinder ....
- All other cylinders between 165-178 .. #3 is about 155
- Do I need a valve adjustment maybe ? Or is it build up on valves ? (Never changed valves, just cleaned them up a bit)
- Car sat a while, this is a long shot, but could it be a sticky ring ?
- some valves had build up but I took off as much as I could
Old Apr 20, 2013 | 07:12 PM
bdlawnic's Avatar
Default Re: Compression Test: 20 Psi below cylinder #3
I am looking for a similar answer. My compression is 180 - 150 - 170 - 180. My #2 is worrying me.
Old Apr 20, 2013 | 09:35 PM
How does your car run ? what's your setup ? Pull hard ?
Old Apr 21, 2013 | 04:29 AM
grumblemarc's Avatar
The Grumpiest
I would suspect the valve stem seal.
Old Apr 21, 2013 | 06:36 AM
bdlawnic's Avatar
Just bought it. 1995 Acura Integra SE all stock b18b1.
Old Apr 21, 2013 | 01:01 PM
Hmmm .. how so ? What can I do about it
Old Apr 21, 2013 | 01:34 PM
The Grumpiest
Never mind. I was thinking of another symptom when I wrote that.
Do a leakdown test to show were you're losing compression.
Old Apr 21, 2013 | 06:27 PM
Will do soon .. don't own a leakdown tester, but I'll talk to a few friends
Old Apr 23, 2013 | 04:09 PM
Jimmy Wyrick's Avatar
look on youtube for using youre compressoin tester to leakdown test
Old Apr 25, 2013 | 01:21 PM
boostedjd's Avatar
it was fine before you swapped heads and how its low... warped head maybe?
Old Apr 25, 2013 | 01:22 PM
boostedjd's Avatar
or headgasket
Old Apr 28, 2013 | 06:57 AM
No over heating issues or leaks, not burning fluids at all .. I doubt it's a head warped or head gasket problem
Old Aug 19, 2013 | 08:31 PM
wayneDOHC's Avatar
bump
Old Aug 22, 2013 | 09:49 PM
dude_123's Avatar
Under ASE specs you are fine. +/- 30 PSI is the max allowable limit. My guess, valves seats are pitted/worn or not seated yet since you did mentioned u cleaned them.
Old Aug 24, 2013 | 09:31 PM
wayneDOHC's Avatar
I had a similar problem on my gsr. took the hose for my compression tester, took the valve out of the engine connector side, twisted the hose in the low comp cyl, and then hooked it up to a compressor with about 95 psi, **with the cyl in question at TDC**, then listened to where the compression was leaking from.
Brandon Peters
Oct 18, 2015 05:40 PM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
evotux
Nov 20, 2006 07:01 PM
Da1spaz247
Nov 4, 2005 07:57 PM
street dreams
Nov 21, 2004 04:48 PM
