high idle on startup?
Old Apr 18, 2013 | 06:15 PM
93eghatchftw's Avatar
Default high idle on startup?
Long time H-T.com reader ,first time posting. I recently did a D16Z6 mini-me head on my D15B7 block and it didn't work out so good,bad throttle response and it had low idle,i don't know why, and so i decided to put my perfectly fine working D15 head back on. Now when i first started the car it started ,BUT, the RPM went straight to around 3800 to 4000! I've searched and troubleshooted with idle screws to cleaning my IACV, checking my vac lines, and nothing. so what could my problem be? I haven't driven my DD car in 2 weeks now and i just don't know what to do.
Old Apr 18, 2013 | 06:27 PM
azzazel_9's Avatar
Default Re: high idle on startup?
Vacuum leak somewhere.
Old Apr 18, 2013 | 07:12 PM
TIMMY4TOES's Avatar
Or you could have put one of the lines backwards. Does it keep on doing it once it is warm? I would get nice schematic and reconnect everything again
Old Apr 18, 2013 | 07:15 PM
crazyhouse2011's Avatar
Screw that D series motor. If you have the stacks just drop in a b16
Old Apr 18, 2013 | 07:16 PM
TIMMY4TOES's Avatar
Have u also tried you idle control adjustment?
Old Apr 18, 2013 | 07:17 PM
TIMMY4TOES's Avatar
I would say h22 lol
Old Apr 18, 2013 | 07:21 PM
i don't know, i don't keep it on that long it scares me lol. I do something that I've searched and troubleshoot and if it doesn't change idle I turn the car off.
Old Apr 18, 2013 | 07:23 PM
no i dont have 'the stacks' lol but im trying to keep it just cause its a real good gas saver (1.5)
Old Apr 18, 2013 | 07:27 PM
oh and exactly, how do i adjust the idle control?
Old Apr 26, 2013 | 07:26 PM
EJ1Lovett's Avatar
adjust the throttle cable?
vacuum leak?
try adjusting your distributor if you dont have adjustable cam gears
Old Apr 26, 2013 | 08:02 PM
xile6's Avatar
That's a high idle I'm going to say intake gasket leak or leaking injector oring.
Old Apr 26, 2013 | 08:57 PM
problem solved. wow. was missing a throttle body gasket. cant believe it made that much of a difference though, i mean...cold start jumping straight to 4000 rpm ? thanks for all the replies.
Thagoldenb
Jan 5, 2011 05:12 PM
ketchup
Feb 5, 2009 08:55 AM
averyvm
17
Jan 17, 2007 11:51 AM
jetlude
Aug 1, 2006 11:09 AM
slow02ss camaro
Jul 31, 2002 09:05 PM
