bad vss or gauge cluster??
Old Apr 15, 2013 | 09:23 PM
mitchh29's Avatar
Default bad vss or gauge cluster??
The other day I was driving and my speedometer was doing its usual bouncing around. Its done that since I bought it and had it fixed for a short time by wiping off the vss. Suddenly it jumped way passed 140 and the needle got stuck pointing straight down.
Now when I turn the power on it jolts clockwise between say 6 and 8 o'clock. When I accelerate it tries to go clockwise but gets stuck just below 0mph cause it will not go further.
My question is can I just replace the vss and the needle with fix itself or do I need to replace the cluster, or BOTH????
95 ex 5 speed with b16 swap.
Old Apr 15, 2013 | 09:36 PM
ej7attack's Avatar
Default Re: bad vss or gauge cluster??
start with the vss. if the needles dont pop back disassemble the cluster and put the needles back in their resting area.
Old Apr 16, 2013 | 02:05 AM
B_Swapped93's Avatar
do you have a friend who would let you borrow his GC for a bit. try that first since you say wiping the VSS fixed it(wipe vss again tho)
Old Apr 16, 2013 | 06:42 AM
mitchh29's Avatar
I don't know anyone else with a civic that has a cluster compatible with mine. I'll be disconnecting the vss fully today and cleaning the crap out of it.
Old Apr 16, 2013 | 09:29 AM
mitchh29's Avatar
Well I cleaned out the vss and took apart my cluster and rotated the needle back to normal and did a couple laps around my works parking lot. But to no avail. Speedometer doesn't even move now. Gonna try soldering the pins on the back of the cluster when I get my hands on a gun. Anyone have ideas to try other then that?
Old Apr 16, 2013 | 04:11 PM
mitchh29's Avatar
Update: I guess the speedometer was just not registering at low speeds going around in the parking lot. Got it on the road and for the first 1/4 mile it was hesitant about giving an accurate reading but then evened out to proper.
406EVO
May 18, 2016 11:26 AM
ctr status
Mar 9, 2008 12:13 PM
gwchndlr
Mar 20, 2007 03:20 PM
kamakaze1
Oct 27, 2006 06:31 AM
