Swap problems, d16y7 to d16y8
Old Apr 15, 2013 | 01:05 PM
jason11fitz1's Avatar
Default Swap problems, d16y7 to d16y8
I have searched and can not find an answer, I have and engine out of a 97 Honda civic si (d16y8) auto transmission and I swapped it into my 99 civic hatchback, using my d16y7 distributor and harness, car runs off my stock ecu, but I have the p2p computer from the 97 si, what do I have to do to get that ecu to work, it will plug in but no spark and fuel pump does not prime but runs when winding over.
My understanding its a obd2a computer and engine but I'm using a obd2b complete harness, I am hoping to use this harness and wire up the vtec, wgat can I do to get this to work
Thanks for the help been trying to figure this out for days
Old Apr 16, 2013 | 06:33 AM
kyden's Avatar
Default Re: Swap problems, d16y7 to d16y8
You need an obd2b to obd2a adapter.
Old Apr 16, 2013 | 08:02 AM
HondaPartsHero's Avatar
Technical Hero
You don't want to use that p2p unless your car is auto. If your car is 5 speed you'll need a 5 speed p2p and will need to wire up vtec, knock, and the 2 wire IACV using a 5 speed intake manifold.
Old Apr 16, 2013 | 09:21 AM
xile6's Avatar
most stuff covered.
dont forget y7 ecu uses 190ccinjectors
while y8 uses 240cc injectors.
Bobby Johnson
Mar 16, 2017 10:10 AM
Wrench6
18
Jul 4, 2015 10:50 AM
2816911965
Jan 10, 2015 07:18 AM
druidesque
Aug 18, 2009 04:41 AM
Angry
Jan 17, 2007 05:51 PM
