Z6 vs y7 oil pump difference?
Old Apr 13, 2013 | 09:32 PM
Gemar's Avatar
Default Z6 vs y7 oil pump difference?
I'm having a small leak from under my hermonic balancer. No other leaks from the oil pan gasket. I used a y7 oil pump on my z6 block (miss placed the z6 pump at the time of rebuild). Im assuming the seal on the y7 is my issue. I see an accumilated ammout of assumbly lube under my timing belt on top of the oil pump. Should I put the z6 pump back on with new seal? Or just change
The y7 seal??? Thanks
Old Apr 14, 2013 | 12:55 AM
apexi_rsx's Avatar
Default Re: Z6 vs y7 oil pump difference?
the pan on the y7 and z6 are different around the snout... if ur using a y7 pr y8 oil pump on a z6 u have to use a y7/y8 oil pick up and oil pan on a z6.... iif u do not have a y7 oil pan then your best bet is to put ur z6 oil pump back on
Old Apr 14, 2013 | 02:15 AM
Gemar's Avatar
Is there a printed code on the pumps to tell them apart. I have another pan just not sure which one it is, my z6 or my y7 or possibly a d15 i ripped apart a while ago. Id have to look and see what oil pick up i have too. Hopefully i have both so i can just switch it all back to z6. Lol thanks
Old Apr 14, 2013 | 06:55 AM
apexi_rsx's Avatar
the y7 pan says p2e on the oil pan.....
Old Apr 14, 2013 | 07:30 AM
94EG8's Avatar
Seagull Management
The pumps are easy to differntiate. Y7/Y8 will have the mounting bosses for the CKF sensor, Z6 wont. D15 will have a smaller diameter seal and hole and wont fit a 1.6L crank.
As far as the pans, OEM Y7 will indeed have P2E stamped in it, also the dipstick hole in the baffle will be on the side. D15/Z6 is the same and has the hole in the middle of the front of the baffle.
h23vtec_dc2
Apr 6, 2014 09:39 AM
94EG8
10
Jan 19, 2014 02:29 PM
evosix
May 4, 2007 08:55 PM
sirsol66
15
Sep 11, 2006 09:59 AM
SRd240sx
Aug 7, 2006 05:19 AM
