Timing question on built b series
Old Apr 7, 2013 | 03:23 PM
bpoweredeg6's Avatar
Default Timing question on built b series
Had a gsr block and b16 head fully built and put together. Running skunk2 pro 2s and I noticed the cam gears are maybe off half a tooth to a full tooth. Now my question is are they supposed to be like that bc of the cams or is it supposed to be lined up and then adjusted from the cam gears on the dyno?
Old Apr 7, 2013 | 03:57 PM
98vtec's Avatar
moderator emeritus
Default Re: Timing question on built b series
This will depend on how much, if, the head has been milled and/or the block decked.
It could simply be off.
We wont know this or anything else without more information from you.
The cams have nothing to do with being able to put an engine in time.
Old Apr 7, 2013 | 03:59 PM
98vtec's Avatar
moderator emeritus
This also belongs in the tech/misc section
Old Apr 7, 2013 | 04:10 PM
yes the head was resurfaced, i wanna say about .006 what else do you need to know?
Old Apr 8, 2013 | 08:04 AM
I'm just gonna set it as close as I can get it
Old Apr 8, 2013 | 08:11 AM
98vtec's Avatar
moderator emeritus
so it was resurfaced flat. That isnt going to make much difference in engine timing unless the head was milled down prior to that resurface. If it has only been resurfaced flat once, there should be no problem getting the marks to line up.
all-mtr-teg
Jan 12, 2007 09:25 AM
gATOr65
Dec 27, 2005 02:03 PM
thehatchninja
Jun 4, 2005 08:28 PM
lilredhatch
Jun 1, 2004 05:19 PM
slowassgsxr750
Mar 10, 2003 09:32 AM
