turbo oil pressure
hello question i just put my gsr engine back into my dc integra fresh from the machine shop they put everething back together new pistons rods arp headbolts ported polished head etc i just turned my car over and the oil light came on turned it off and checked my pressure switch it was connected so i took the turbo line off the back of the block and no oil seems to be passing trew the line so i removed the adapter to the block and pressure switch and cranked the motor over to see if oil comes trew for like 5 seconds and mo oil comes trew any help please thanks
na, that shouldn't effect anything, leave it on. Did you put a new oil pump on? did they make sure the oil tube in the pan was put back on? if not, it ain't gonna suck up any oil.
il have to check just it was all put back together when i got it from the machine shop i just basically dropped it in bolted everething back up put oil and turned it on i just turned it on no light comes on without anything on
Verify your oil level and be sure to prefill your oil filter (which should already be standard practice). Disconnect the ECU (or fuel and ignition another way) and crank the engine over for 30-60 seconds in 10 second intervals giving the starter a 10 second or so break in between. You can do all of this with the sandwich plate hooked up.
yeah i dont have a sandwich plate on my gsr im running my turbo feed line with an adapter where my oil pressure switch connects its a fitting screwwed into the block with a fitting going to my turbo line and the pressure switch srewed at the back
Sorry, I misread... either way, you can test it like that if you choose to do so. A way to verify if the turbo is getting oil is to disconnect the drain line. You should see a steady flow.
yeah im pretty sure theres no oil going trew i took the feedline out and adapter where the pressure switch moints to the back of the block next to where the oil filter goes and no oil is passing trew smh im going to buy a new pressure switch tomorrow and check if it hopefully works and i checked my dipstick and oil is still at level
Who is Mr Robot?
You can't just keep cranking it, assembly lube only lasts so long.
Drop the pan an verify that the pickup and pickup gasket are in place on the oil pump,
Then fill to proper level and try again.
on a fresh motor i always put oil in the filter, also i crank the motor with the distributor unplugged untill the light goes off. Usually takes about 30 seconds for it to build pressure in the entire motor. After that I plug in the dizzy and fire it up. i use EXTREME amnounts of moly assumbly lube on my builds LOL
pelotudo
Aug 18, 2002 06:31 PM
