1992 Honda civic trouble starting
Old Apr 3, 2013 | 04:46 PM
chandler58's Avatar
Default 1992 Honda civic trouble starting
1992 Honda Civic LX L4 - 1.5L 1493cc type D15B7 - MFI SOHC
I finally got my car running (started). Changed fuel pump. Changed relay. Pump primes. Car starts. Now it takes 10 minutes for pump to prime and run. I feel that it will just not start at all, eventually. My ECM looks to be my problem, I think. does anyone know how to test it out without getting another one? Or any idea of what is going on?
Old Apr 3, 2013 | 04:59 PM
Former User's Avatar
Default Re: 1992 Honda civic trouble starting
Clean the G101 ground on the thermostat housing and replace fuses 24 and 31. If the problem persists, replace the ECU.
Old Apr 3, 2013 | 09:04 PM
chandler58's Avatar
Is the G101 groound the only ground for the ECU? It seems like only the blue/white wire from ECU don't go on, but the ECU gets power. That is my outlook on my problem.
Old Apr 4, 2013 | 01:15 AM
Declectic's Avatar
is it cranking or not cranking?
manual or auto?
Old Apr 4, 2013 | 03:48 AM
albyneau's Avatar
New here, and to Hondas~ but the guy I got my car thru is the premiere Honda wizard in a 3-county radius. If getting fuel on startup is your issue, a common problem with these is the main relay, tucked up under dash by your left foot. They're pricey little buggers, so he gave me a small wire to jump the fuel pump primer circuit when the occasional no-start occurs~ but it's only happened once, and darned if I remember which two terminals to jump. I'm thinkin a $5 momentary switch (versus a $60 relay) to circumvent the issue for the time being.... Hope this helps... somebody....
Old Apr 4, 2013 | 04:08 AM
Yes
Th blue/white wire only gets voltage when the key is held in ON(III).
Old Apr 6, 2013 | 12:00 AM
chandler58's Avatar
manual or auto?
it cranks and is auto.
Old Apr 6, 2013 | 12:02 AM
chandler58's Avatar
been busy. but gonna clean around the G101 ground and replace fuses. update soon.
Mr. M
Nov 6, 2013 01:32 PM
averyvm
Engine Management and Tuning
17
Aug 2, 2013 05:40 AM
lledcomp
Apr 5, 2007 06:20 PM
LOGICx420x
Sep 19, 2005 08:08 PM
Senbonzakura
Jan 2, 2005 05:16 PM
