Rain/Humidity Fuel Pump Engagement
Old 11-04-2013, 09:09 PM
Mr. M's Avatar
Default Rain/Humidity Fuel Pump Engagement
Hey what's up guys, I have recently purchased a 95 Honda Civic DX and everytime it rains, the car does not want to start at all. I have to wait for it to dry off until the fuel pump wants to enage again, then were fine. I cleaned all of the grounds, and still im getting issues. i pulled the main relay, tested it and it came out fine. Im not sure what else could be making the car do this. Can anybody help me????
Old 11-05-2013, 01:14 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: Rain/Humidity Fuel Pump Engagement
Resolder all the main relay contacts and retry.
Old 11-05-2013, 01:44 AM
Mr. M's Avatar
I already did that, so what's the next step to that?
Old 11-05-2013, 02:40 AM
jbpnoman's Avatar
You said you only tested it, so did you test it, or did you actually resolder it?
Old 11-05-2013, 11:47 AM
delsolintegra's Avatar
Could be the ECU. Common problem. Moisture effects the circuit board capacitors especially C14. Try another known good ECU.
Old 11-05-2013, 02:35 PM
Mr. M's Avatar
Okay, I could do that. It is damp on the passenger side, I'm not sure where the water is coming it. How would I get to the ecu?
Old 11-06-2013, 04:19 AM
The ecu is located under the carpeting on the passenger side footwell wall.
It's held in place by a brace with 10 mm bolts. Remove the bolts and when the ecu is free you will have enough slack to remove the wire harness connectors. There is a label on the side of the ECU with a part number. You want to get the exact same ECU to avoid complications. Check with local junk yards for that part number. Probably about $125.
Old 11-06-2013, 04:22 AM
When I replaced my ECU I hung a piece of plastic over it to act as a moisture shield.
Civics leak in that area thru the body and fender well.
Old 11-06-2013, 12:24 PM
Mr. M's Avatar
How did you do that? What kind of plastic did you use?
Old 11-06-2013, 01:32 PM
I used a piece of plastic drop cloth and just made a tent over the ecu before I rebolted the ecu in place. I didn't seal it tight or it would trap moisture inside the plastic. I just didn't want moisture from above drip or condense on the ecu body. Than I placed the carpet back over the ecu.
Whiteonblackej
82
03-19-2015 12:55 PM
Dustin19902
11
11-18-2014 12:34 PM
moaterboaink1ng
10-10-2012 09:07 PM
bc matt
04-02-2005 01:17 PM
rwcdrums
06-19-2002 06:15 PM
Quick Reply: Rain/Humidity Fuel Pump Engagement
