what compression for lsvtec stock sleeve 93octane
Old Apr 2, 2013 | 11:24 AM
3easy21's Avatar
Default what compression for lsvtec stock sleeve 93octane
Which compression would be best for a lsvtec turbo using a precision 57trim .63 3431e , log manifold, 3" dp and exhaust. B16 head port n polish gsr cams. The goal is around 400.whp a street car that hits the drags on the weekends. I have 3 pistons in mind the wiseco k541m815 which I think will yield 9.0cr, the wiseco k542m815 which will yield 9.8cr, or supertech p4-h815-n2 which will yield about 10.2 cr.
Thank you
Old Apr 2, 2013 | 11:47 AM
boosted_D's Avatar
Default Re: what compression for lsvtec stock sleeve 93octane
Well, according to simple compression calculator :
wiseco k541m815 which I think will yield 9.0cr 8.66:1 ACTUAL
wiseco k542m815 which will yield 9.8cr 11.28:1 ACTUAL
supertech p4-h815-n2 which will yield about 10.2 cr ACTUAL 10.1:1
So I would go with the supertechs You should be sure of what the actual c/r is going to be b4 you make choices like this!
Old Apr 2, 2013 | 12:25 PM
Muckman's Avatar
Moderator in Chief
Agreed you def need to run the compression calculations before deciding. http://www.zealautowerks.com/bseries.html
Personally I would never build a street engine under 10:1 anymore. Many stock S2000s with 11:1 compression make excellent power on mild boost and pump gas. I would not be afraid of 11:1 compression with a well built, well tuned engine.
Longbow
Oct 9, 2010 10:22 AM
EdSales
Feb 9, 2010 07:01 AM
chapagetti
Apr 2, 2009 01:08 PM
Kellindal
Dec 22, 2001 07:38 PM
OneThirtyEight
Dec 1, 2001 10:19 PM
