Will I need to lower compression with this setup?
Old Feb 9, 2010 | 06:16 AM
EdSales's Avatar
Default Will I need to lower compression with this setup?
I'm getting ready to Turbo Charge my Hatch. I was going to put on a Buddy Club 2MM Thick Headgasket, however, I did some searching and found quite a few horror stories on adding Aftermarket Headgaskets.
I have a completely stock JDM B16A, and my goal is 300 WHP for aggresive daily driving. Will I need to lower compression, or will it be stable for my goals and needs?
Old Feb 9, 2010 | 06:55 AM
shifty35's Avatar
Default Re: Will I need to lower compression with this setup?
I wouldn't sweat lowering compression, you can do 300 whp on pump gas and stock compression.
Mutiny1's Avatar
I would probably go with a set of Forged pistons around 9.0:1 or close. You can probably get away with boosting with the stock pistons and compression just fine but honda pistons start to crack around the ring glands on boost, which will make you loose compression and smoke like a diesel.. been there done that..
Old Feb 9, 2010 | 07:01 AM
90blackcrx's Avatar
First do a compression test and leak down, see how healthy the motor is. If the motor is healthy go for it, 300hp on a b16 won't be to hard to achieve, you will need to upgrade a few things on the top portion though ( head area like cams, intake manifold and such )
CivicDude2k4
18
Oct 8, 2006 09:13 PM
genop
Sep 17, 2003 10:45 PM
sushibug
Apr 3, 2002 05:04 PM
Kellindal
Dec 22, 2001 07:38 PM
OneThirtyEight
Dec 1, 2001 10:19 PM
