Raising Compression
Old Dec 21, 2001 | 04:32 PM
Kellindal's Avatar
Default Raising Compression
Ok, I have a 98 GSR, and I have some questions about raising compression:
1. What is involved with raising compression. Obviously i know that you need higher compression pistons. But what other internals need to be strenghtned?
2. What kind of gains can you get from ITR pistions in a GSR? Is it worth it, or are other aftermarket pistons considerably better?
3. Am i gonna have to worry about clearance issues? What causes them? What are they?
4. How much would raising the compression after all the work cost?
5. How do the gains compare to getting bigger cams and tuning them?
Any other info on raised compression would be nice and appreciated.
Thanks.
Old Dec 21, 2001 | 07:40 PM
IMPATIENT's Avatar
Default Re: Raising Compression (Kellindal)
if you raise compression you should definitely gain some power, like you said, need higher compression pistons, i believe you'll need to get a different set cam and adjust the head with different valves and retainers and **** like that to compensate for air flow..........get some nos, or turbo and you;ll be much happier and you won;t have to tear the motor apart...virtually no down time.......
Old Dec 22, 2001 | 10:30 AM
owen_the_soyboy's Avatar
you can remove the head and have it milleed a bit.. like .020"
while the head is off you can remove the valvetrain and upgrade it.. new springs and retainers, new cams, new adj camgears... then you are all set to get a new chipped ECU with a higher redline and make the most of your new cams and higher compression.
Old Dec 22, 2001 | 07:38 PM
Kellindal's Avatar
Default Re: Raising Compression (owen_the_soyboy)
So if i want to raise the compression, I have to upgrade all other internals INCLUDING cams? I'm looking for an N/A application other than cams to do. Something less expensive. I thought higher compression would be good, but not if i have no strengthen all my internals anyway. Maybe just some head work like port and polish...
So, i have to upgrade all internals to raise compression?
Exeed
Apr 18, 2006 11:04 AM
zoom545
Nov 22, 2005 09:04 AM
mrduque
Apr 24, 2003 10:17 AM
VTC_CiViC
Jun 28, 2002 08:05 AM
