Wastegate pipe out of turbo collector HELP!
Guys,
I have came accross a huge problem.
After I have finished a 6 runner manifold for an BMW M3 my client came and told me that he wants to mount an 60 mm wastegate.
But there's some problems:
-there's no space to make the exit from the collector with an 60 mm due to the elbow will touch the turbo housing
-the collector is too short to mount an 60 mm elbow
-the oil return pipe can't be mounted safely away from big heat
-the hot intercooler pipe is almost imposible to mount with an 60 mm pipe.
Therefore I have made an 48 mm elbow with an reducer from 48 to 60 mm....like in the photo.
Is this OK???
Is this OK???
Eg
http://www.google.com.au/imgres?q=ex...82&tx=82&ty=60
Even if you get it all mounted up well, what is the point of running a 60mm gate, when the inlet the the elbow is only 48mm? It will still flow closer to a 44mm than a 60. I think your idea will work. I would just stick with a 44mm gate. From the customer end, I would rather be told my plan wont work as well as I think, then pay someone to "do what I want". Just me maybe.
SPOOLINmatt
Dec 7, 2012 05:56 PM
Adi Radoncic
Dec 15, 2005 12:52 AM
