flex pipe on closed loop downpipe?
Old Jan 30, 2006 | 02:37 PM
HamiltonRex's Avatar
Default flex pipe on closed loop downpipe?
Hi, im adding in the part of my downpipe where the wastegate pipe cuts in.. Im going to go in once its straigh (under pan) and on like a 45deg angle..
The downpipe has a flex pipe, do i need a flex pipe for the wastegate as well?
It will be easier to do without.. but i dont want it cracking, im using 1.75" piping (mild) and 3" stainless for DP.
Thanks.
Old Jan 30, 2006 | 02:46 PM
JG-Fabrications's Avatar
Default Re: flex pipe on closed loop downpipe? (HamiltonRex)
Yes you should run a flexpipe because there is a heat difference before the turbo (wastegate) and after the turbo (downpipe) and the flexpipe allows for expansion and contraction because the wastegate isn't open all the time, the pipe will rapidly heat up and cool down
-James
Old Jan 30, 2006 | 06:11 PM
Default Re: flex pipe on closed loop downpipe? (JG-Fabrications)
ok thanks.
Dont want any chances of cracking on this thing. Plus i have lots of room for one anyways.
Old Jan 30, 2006 | 06:15 PM
93turbo16's Avatar
I would also say run a flex pipe for the wastegate as well.
ramboPandA
Apr 12, 2016 08:42 AM
importimage
Jul 13, 2003 09:56 AM
scooter
Jul 5, 2003 01:24 AM
ntegls
Jun 3, 2003 07:03 PM
