Swaping mounts
Old Mar 31, 2013 | 04:11 PM
rhdcivic05's Avatar
Icon2 Swaping mounts
I have a 97 civic ex i was going to put a obd1 b16a motor in and didnt know if i had to go online to buy a $250 pair of motor mounts.. I wouldn't mind checking into what stock mounts or what not i would be able to use.... if anyone can help or have a site that would fill in the blanks.
thanks
Old Mar 31, 2013 | 04:26 PM
B_Swapped93's Avatar
Default Re: Swaping mounts
thanks
Unless it doesn't come with mounts or the ones it comes with are bad there's no need to buy new ones. Unless you just want to upgrade an obd1 engine's mounts are no different from an obd2.
Old Mar 31, 2013 | 04:40 PM
rhdcivic05's Avatar
I thought that the mounts was different like the trans mount is different or eg mounts dont align right.
Old Mar 31, 2013 | 04:45 PM
Not that I know of. If it is then you can just buy a tranny mount seperate. but i really don't think so.
Old Mar 31, 2013 | 04:46 PM
carlos8's Avatar
you can use your stock mounts. But if you have some busteds or the car going to be turbo or drag race get a set of aftermarkets.
Old Mar 31, 2013 | 04:52 PM
rhdcivic05's Avatar
thanks for the input
Old Mar 31, 2013 | 09:12 PM
jbpnoman's Avatar
The only mount you will have to change is the rear T bracket mount. You can get it out of a 99-00 SI. You'll also need to make sure the driver's side mount is correct - there are 2 and 3 post variants.
cruizer
Sep 15, 2009 07:24 AM
D16SohcVtec
Aug 12, 2008 08:03 AM
NAmodified
Oct 16, 2007 08:35 AM
VTECcnIT
Apr 17, 2006 07:54 PM
racingant
10
Mar 13, 2004 07:17 PM
