Tran slip...
Old Mar 29, 2013 | 06:51 AM
BlackFlame11's Avatar
Default Tran slip...
When it's cold, my transmission slips. Any reason why this would be happening?
Old Mar 29, 2013 | 07:28 AM
brages's Avatar
Default Re: Tran slip...
because it's worn out and about to fail
Old Mar 29, 2013 | 08:00 AM
Awesome news. Haha.
Old Mar 29, 2013 | 08:11 AM
kennyvilla's Avatar
That sucks I gotta replace mine to.
Old Mar 29, 2013 | 08:41 AM
Well, I'll have to get an Engine/Transmission combo.
Old Mar 29, 2013 | 12:55 PM
Mishako129's Avatar
My transmission shifts a little hard from 1st to 2nd. I don't know what it could be, is this normal?
Old Mar 29, 2013 | 12:58 PM
Shifting hard itself? Or the engine kind of jerks during shifting?
Old Mar 29, 2013 | 01:07 PM
Mishako129's Avatar
The whole car jerks, I can't tell if its the engine or trans, feels like both though. Its an auto.
Old Mar 29, 2013 | 04:19 PM
djkurious's Avatar
Changed fluid?
Old Mar 29, 2013 | 09:56 PM
Mine did the same. Check the engine mounts. One on front, one on left and right, and one on the rear. Four total. I thought mine was broke. Turns out the attachment point of the mount on the engine was broke off and someone literally glued it back on. You most likely won't have that problem. None of the mounts are more than $100. And if it's your driver side mount, go ahead and change your timing belt at the same time. Let me know. Hope this helps dude.
Old Mar 31, 2013 | 06:56 AM
Lost Again's Avatar
No one is giving years here so.......
Cold shifing issues, are you using non Honda Trans fluid?
Hard shifts (cold and warm)- Pre '98, check the throttle control cable from the TB to trans for proper adjustment and movement.
As always, check all mounts.
Old Mar 31, 2013 | 07:16 AM
How do you know the correct adjustment?
Old Apr 1, 2013 | 02:35 PM
Lost Again's Avatar
By following the service manual procedure.
Old Apr 1, 2013 | 06:23 PM
Oh. I don't have one. I'll have to research.
Old Apr 1, 2013 | 06:43 PM
Mishako129's Avatar
The rear mount I know is bad, I would replace it by removing the intake manifold (easiest way) but the seller on ebay is taking forever to ship the heat shield gasket I ordered. Gonna swap in a emptied out H23 manifold at the same time, that'll be fun seeing what that does to performance.
Old Apr 2, 2013 | 06:55 AM
Sweet!
VTECwalka
May 3, 2012 07:23 PM
Dogginator
Dec 12, 2010 10:55 AM
shewit08
18
Jun 21, 2010 05:34 PM
sealz
Acura TSX
Mar 15, 2008 10:21 PM
ajth87
Apr 10, 2006 04:05 PM
