No Power to Distributor!
I have a 2000 civic coupe getting no power to the dizzy for spark and it is not starting.
I have fuel (fuel pump kicks on), new ngk plugs and ngk wires along with cap and rotor all new. All fuses have been checked up hood and dash along with #9 ignition fuse.
I have used a test light and checked right out of the harness no power. Looked at saftey switch on clutch pedal appears good. I have drove the car last two days runs awesome.
Can't figure this out any help please!!!! Thanks Trevor
I have been driving the car all day multiple starts and stops at places was at Discount Tire leaving and car just cut off thought I stalled it tried to start it back up nothing I've been in the parking lot since 3 messing with it.
Just put two different ecu's in it from the one I was driving with and still nothing!
I did that because I was just double checking to make sure my ecu wasn't bad so from there I did the trouble shooting after trying the most simple thing and come to find out like I said there was no power out of the engine harness to the dizzy
I finally pulled out the engine harness and check both end where it plugged into the chasis they had power but wasn't making it through the harness untaped it and chaffed power wire!
I appreciate the effort and help. Learned something new though testing the ICM
There's a ground wire that's supposed to go righ on top of the thermostat housing, my car ran like doookey when it was loose. May look at that and tighten it if you have t already
Guys the socket that connects to the distributor (OBD1) from wiring harness, does all the pins on the top should have power during ignition on!!. According to my understanding 4 on the top should be power and 3 on the bottom should be ground ??
93hatchbake
34
Sep 3, 2014 02:57 AM
