How do i set EK manual trunk to automatically lock
Old Mar 28, 2013 | 04:50 PM
JJT211's Avatar
Default How do i set EK manual trunk to automatically lock
I just put a system in my 98 EK Civic Cx. My trunk is a manual lock/unlock and alot of times I forget to lock it. I just want my trunk to auto lock like the other cars trunk do cuz I know it will bite me in the *** one day.
Is there anyway I can set my trunk to lock automatically without me having to physically lock it every single friggin time. If not, any mods??
Old Mar 28, 2013 | 05:30 PM
grumblemarc's Avatar
The Grumpiest
Default Re: How do i set EK manual trunk to automatically lock
Yeah. Fix it because it sounds like it's broken.
Old Mar 28, 2013 | 07:47 PM
v!taminb16's Avatar
New lock or just twist left to the left
Old Mar 28, 2013 | 07:48 PM
Libertariat's Avatar
Ek Forever y0!
Yes, wire a power lock actuator to the locking mechanism.
Much like installing power locks onto the doors. Just have to run wiring back there.
I had a 97 civic, and I needed the key to open the trunk every time. I'm not positive about the 98 hatchback, do you have a key only opening hatch or is there a handle you pull? For some reason I want to say the 98 got the updated hatch like the 99 and 00 have.
Maybe it's just been too long of a day.
Old Mar 28, 2013 | 08:23 PM
JJT211's Avatar
And no its not broken, I can lock it. There's a handle I pull and it acts EXACTLY like a regular car door. I want my trunk to act like a trunk.
Keep in mind this is a CX. This car is manual steering, trans, windows, locks, everything. Im actually quite surprised it has AC
Old Mar 28, 2013 | 08:27 PM
Ek Forever y0!
I have the same hatch design. The only solution is really for you to install a power lock actuator and wire it in with your keyless entry/alarm.
Old Mar 28, 2013 | 08:33 PM
JJT211's Avatar
Well what about regular trunks, and just about every other car ever made? There's nothing power about the trunks. Its just a mechanical mechanism that only opens by key.
Is the Dx and every other Civic Hatch the same way? When I was 16, I had a 84 Civic Hatch and I could swear it being a regular trunk. It def wasnt power locks/windows or anything. Just a key and no handle.
Old Mar 29, 2013 | 03:45 AM
Ek Forever y0!
No, the 96-97 hatch must be opened with a key. I suppose it's a little outside the norm.
Old Mar 29, 2013 | 04:57 AM
The Grumpiest
What am I missing here? I have a 97 hatch. From the outside the key is needed to open the hatch but locks when you close it. Same with the 96 Coupe. From the inside they both have the release mechanism to open them.
Are we saying that the years after that the trunks on these things does not lock when you close them?
Old Mar 29, 2013 | 06:27 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Yeah what is the deal, mine always locks when you close it, 96 CX,.
Old Mar 29, 2013 | 06:41 AM
The Grumpiest
Now that I recall every Honda I've ever owned worked this way. What am I missing?
Old Mar 29, 2013 | 07:39 AM
Ek Forever y0!
In 98 they switched to a different trunk through 99 and 00. It has a handle like a door handle to open, and to lock it you must lock it with the key manually or there is a vertical pin that can be pressed or pulled from inside.
Old Mar 29, 2013 | 07:42 AM
The Grumpiest
Okay. That just sounds dumb.
Old Mar 29, 2013 | 11:08 AM
JJT211's Avatar
Glad we're in agreement here....is even more dumb than I thought! Its right up there with the cabin air filter-less ac system.
Libertariat, you're saying its a diff trunk and the 96-97 trunk latch isn't plug and play with my 98 cx?
Old Mar 29, 2013 | 11:18 AM
kyden's Avatar
the trunk shells have a different part number from 98+ so I would assume they are not the same.
Old Mar 29, 2013 | 11:38 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Yeah and from what I recall - the 96-97 trunk hatch is not plug n play with the 98-00? Though this is just from a vague memory ... highly recommend searching before taking my word for it, considering I don't even own a 6G Civic and am no expert.
Old Mar 29, 2013 | 12:10 PM
kyden's Avatar
the 96-97 had a release cable for the hatch also didn't it?
Old Mar 29, 2013 | 12:37 PM
Ek Forever y0!
Pretty sure you could put the 96-97 hatch on if you wanted to.
Old Mar 29, 2013 | 12:40 PM
deschlong's Avatar
Loved
Community Favorite
That sounds right ... later 98-00 year ones had no provision for the interior remote release?
So, any trunk retrofit would also have to include this functionality also.
OP should really consider an alarm with remote locks on the doors and trunk instead of just a trunk retrofit. Security = Win.
Old Mar 29, 2013 | 01:43 PM
Ek Forever y0!
When I redo my alarm that's what I plan on doing. Wiring an actuator in the back of the car will be a joke. Makes no sense not to do it with an alarm install.
Old Mar 29, 2013 | 03:10 PM
Civic12's Avatar
Get a coupe or sedan if you prefer!
Old Mar 29, 2013 | 09:59 PM
JJT211's Avatar
Yea im eventually gonna go with an alarm. But due to financial limitations, can only do it in stages.
Thanks for the info!
URbaby8myDINGO
40
Jan 30, 2015 09:21 PM
Thornton121
May 1, 2014 09:41 AM
RevrsOne
Aug 18, 2012 03:43 AM
FermiumHalo
Feb 14, 2010 03:25 PM
i-vtec_DO_YOOH
Jan 14, 2008 03:38 PM
