starting problem
Old Mar 28, 2013 | 04:14 PM
228rukus's Avatar
Default starting problem
stock 99 civic lx
changed thermostat now it wont start
have spark, fuel and the ground to the thermostat is on good.
will turnover but wont crank, dont see anything disconnected and all fuses look good, can hear the fuel pump prime. any thoughts or suggestions?
Old Mar 28, 2013 | 04:22 PM
B_Swapped93's Avatar
Default Re: starting problem
did you fill you'r rad back up(not that that should cause it not to start). any coolant leaks
Old Mar 28, 2013 | 04:27 PM
228rukus's Avatar
radiator is filled, no leaks
Old Mar 28, 2013 | 06:52 PM
grumblemarc's Avatar
The Grumpiest
What do you mean the ground is "good"?
Old Mar 28, 2013 | 06:58 PM
228rukus's Avatar
not loose
Old Mar 28, 2013 | 06:59 PM
The Grumpiest
How about checking to make sure there's good metal to metal contact. "Not loose" aint cutting it.
Old Mar 28, 2013 | 07:02 PM
228rukus's Avatar
ok sorry there is good metal to metal contact
Old Mar 28, 2013 | 07:07 PM
The Grumpiest
Then you did something else. That or what you think is goo contact is actually not. I've changed a thermostat or two and have never had a car not start.
SkysTheLimit
Apr 23, 2013 05:32 AM
88EFsedan2
14
Feb 11, 2012 09:17 PM
JsSIR
Apr 28, 2009 05:25 AM
Melt Metal
Oct 20, 2005 10:39 PM
