civic electrical issue help
Old Mar 28, 2013 | 02:55 PM
jwaggz21's Avatar
Icon2 civic electrical issue help
i have an 89 civic with a mini me swap d15 vtech. this is a friends car, i rebuilt the enngine for him when i got it back in the car it ran perfect i took it on its first test drive after about 5 minutes of driving it died and would not restart it turns over fine.. after 2 days of diagnostics i have found it is not getting fuel. i have shot it with starter fluid and it fires so i know it is getting spark. now for the tricky part. there is no power to the interior, no lights no blinkers no radio no hazards,
what i have done
checked all grounds
checked fuses visually (fine)
check with testlight power when key is off
check with testlight no power when key is on except number 2 fuse has power no matter what
check fuses with mulimeter only between 6-8 volts at fuses
checked main relay tested good
checked main fuses under hood with test light and multimeter tested good
any help would be great im at a loss
Old Mar 29, 2013 | 05:20 AM
Si Guy 86's Avatar
Default Re: civic electrical issue help
no fuel...have you tested your system (fuel) components individually? Do you have access to a power probe, if so it will make it easier in my opinion
Old Mar 29, 2013 | 01:59 PM
jwaggz21's Avatar
thank you for getting back to my post that is correct no fuel. i do not have access to a power probe. what were you thinking? i really feel the issue is something electrical due to no power in interior. like a main fuse or relay or something like that but everything ive tested come out good. i have never seen an issue like this before so i am stumpted.
Old Mar 29, 2013 | 11:58 PM
jwaggz21's Avatar
got it figured out it was a faulty ground. the one that bolts to the strut tower by the battery. cleaned it up and problem went away
Old Apr 9, 2013 | 12:22 PM
Si Guy 86's Avatar
sorry i didnt get back soon but good work on finding that bad ground,those can be tricky
Crashmaster91
Jun 22, 2017 08:24 PM
skylierwood
Sep 1, 2012 04:26 AM
articsilber323
Sep 18, 2009 10:07 PM
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
BlackBeastEK
29
Jun 15, 2007 06:40 PM
