NEED HELP PLEASE.......
Old Mar 26, 2013 | 05:13 PM
civic1turbo2012's Avatar
Default NEED HELP PLEASE.......
OK HERE I GO... RECENTLY I GOT A 99 LS WITH A GREDDY TURBO KIT, I HAD A B16 HEAD, THE LS CAME WITH 440 DSM INJECTORS, ECU CHIP FOR THE TURBO SETUP, ACCORDING TO THE GUY WAS RUNNING PERFECT.......
SO I TOOK EVERYTHING TO A GOOD SHOP TO PUT EVERYTHING ON MY EK ......
GOT VTEC CONVERSION FROM EAGLE, ARP STUDS, HEAD GASKET, AND ALL THAT
THEN I TURN TO XENOCRON TO GET THE VTEC CONVERSION FOR MY ECU (BEEN THAT WAS NON VTEC BUT WAS BOARD 11F0 SO I DID THE VTEC CONVERSION
AT FIRST I HAD PROBLEMS WITH THE VTEC , THE GUYS DIDN'T DO WIRING PROPERLY AT THE ECU (OBD2 TO OBD1) I SOLVE THAT MY SELF, THEN I GOT PROBLEM WITH THE IDLE THEY DINT WIRE PROPERLY THE ICVA NETHER SO I GOT THAT SOLVE TO..... THEN I TOOK A TRIP TO P.A WHEN I GOT THERE THE CAR START TO BACKFIRE AND DIDN'T IDLE AND CUT OFF , MY WIDE BAND SHOW RUNNING RICH...I CHANGE SPARK PLUG THEN THE CAR BARELY STAR AND EVER SINCE IT SUPER RICH .... I CHECK THE OHMS AT THE INJECTORS THEY 12.4... SOME ONE TOLD ME MAYBE THE DRIVERS FROM THE ECU I TEST THEM WITH A DIAGRAM THAT I FOUND ONLINE AND THE DON'T MEASURE EXACTLY LIKE THEY SHOULD BUT THEY CLOSE ... I NEED HELP.. ALSO I NOTICE ONE OF THE CAMS THE ONE ON THE EXHAUST SIDE ITS A LITTLE LOOSE... TIMING PROBLEMS? NEED HELP PLEASE
Old Mar 26, 2013 | 05:17 PM
grumblemarc's Avatar
The Grumpiest
Default Re: NEED HELP PLEASE.......
All caps on the net is considered shouting and rude.
Old Mar 26, 2013 | 05:19 PM
Patryk_98's Avatar
The all caps is hard to read consider using regular characters.
Old Mar 26, 2013 | 06:47 PM
sorry didnt realize it
Old Mar 26, 2013 | 06:56 PM
so sorry guys , this is my first time posting....
long story short i got ls vtec with a greddy turbo kit, it was running good until i took a long trip now the car its super rich... a mechanic told it because the injector (they are 450 dsm)
they didnt have resistor box, they are not low ohms , they reed 12.4 ohms. he said
the injector fried the ecu drivers witch i could be... dont know.. but i got another p28 and the drivers read the same.... i need help dont know what to look for
Old Mar 26, 2013 | 07:57 PM
EGxBoostFiend's Avatar
I'm having trouble exactly understanding the problem.. But i do know to run dsm injectors you HAVE to have resistors. There's threads on here about how to do it, it sounds like you know how to wire things. I bought my resistors from Radio Shack. I forgot what size you need but I'm sure you can find it here.
Old Mar 26, 2013 | 11:43 PM
xile6's Avatar
Did you put in a resistor box the second time?
If not then your just blowing ecus.
Dso injectors need a resistor box.
Also make sure the car is tune to run the dam 450cc
Old Mar 27, 2013 | 02:39 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Has your car been tuned on a dyno?
Old Mar 27, 2013 | 04:55 AM
Yes i add resistors to the yellow/black lines at the injectors, they are 10 watts 10 ohms.
The chip was made for this setup, and it was street tune.. it was running just fine, at first,
I had some problems because the guy who did the swap didnt do the vtec wiring properly
and iac but i fix all that and i was running just fine until i took a long trip...
The car was pulling really hard with only 7 pounds, by the way i got stop internal on the block, the head its b16 with typer intake manifold, and type r cam shafts...
I did realize that the cam in the exhaust side its a little loose....
blake22
Engine Management and Tuning
May 16, 2011 04:16 PM
MiamiEgGSr
Feb 9, 2008 06:24 AM
hondaluva
Sep 12, 2005 06:12 AM
civic97pr
Mar 21, 2005 01:20 PM
