Help me Please!!! Misfiring problem
Old Oct 22, 2002 | 10:06 AM
vspec12's Avatar
New User
Default Help me Please!!! Misfiring problem
Okay, I have a b16a1 w/ ctr pistons. It ran perfect till one day when i missed gears and over reved it and bent a valve, since then I have gone through numerous reapirs, and still can't figure out why my car still misfires.
this is what I have done:
-I have changed heads
-leak down test checks out, losing 5% acroos through piston rings
-new distributor rotor and cap
-new map
-cat looks okay from inside
-no vacuum leaks
-Timing checks out
-running 45 psi w/ 310 inj
-new pcv sys.
-all inj. click during idle
-new o2 's
-checked the spark plug wires
-new plugs
Any help would be greatly appreciated...thanks
Old Oct 22, 2002 | 10:10 AM
builthatch's Avatar
MiG-21 superfan
Default Re: Help me Please!!! Misfiring problem (vspec12)
cracked ring lands?
[Modified by builthatch, 2:11 PM 10/22/2002]
Old Oct 22, 2002 | 10:16 AM
vspec12's Avatar
New User
Default Re: Help me Please!!! Misfiring problem (builthatch)
but my leak down test checked out... it losing max of 5%
Old Oct 22, 2002 | 10:32 AM
Big Phat R's Avatar
distributor bearing?
Old Oct 22, 2002 | 11:39 AM
Crazydave's Avatar
what did you check on them..
try replacing them
what about the module (did you replace the whole dist?)
double check timing.. and cam timing and belt
Old Oct 22, 2002 | 01:56 PM
Chiovnidca's Avatar
Have you been able to narrow it down to one cylinder?
Old Oct 22, 2002 | 02:37 PM
vspec12's Avatar
New User
Default Re: Help me Please!!! Misfiring problem (Chiovnidca)
no i haven't, how do i go about narrowing it down to one cylinder, all the injectors sound good . it happens when i floor it the misfire occurs, at idle and under load
Old Oct 22, 2002 | 02:56 PM
Chiovnidca's Avatar
It's easy if it acts up at idle. Pull one plug wire at a time to see if the idle speed is affected any. If you find one that doesn't do anything, concentrate there.
DylanGSR_eh9
Mar 9, 2016 05:23 PM
hatchyboy89
10
Jul 17, 2012 02:19 PM
meallout
Mar 19, 2009 11:34 AM
rayzian
13
Dec 18, 2006 03:35 PM
vspec12
Oct 22, 2002 02:55 PM
