1994 civic none starter
Old Mar 25, 2013 | 03:49 PM
Hughes07's Avatar
Default 1994 civic none starter
I'm working on a civic for a mate which won't start.
It's a 94 model with a d15b2 in it. The problem is that it turns over and starts for a second then cuts out.
In ignition position 1 the radio comes on as it should, then in ignition position 2 there are no dash lights when there should be, when you crank it the dash lights come on and it starts but as soon as the key springs back to ignition position 2 it dies again.
I can keep it running by holding the key just in front of position 2 so the starter isn't engaged and it runs fine so it's nothing mechanical.
From what I've read it could be ignition switch, main relay or ignition control module. Which one would be the most likely and is there anything else I could try?
Old Mar 26, 2013 | 01:06 AM
Hughes07's Avatar
Default Re: 1994 civic none starter
Surely someone can point me in the right direction?
Old Mar 26, 2013 | 01:21 AM
jbpnoman's Avatar
Considering the whole "holding it just in front of II" thing, it sounds like your ignition switch is out.
Old Mar 26, 2013 | 04:54 AM
EGxBoostFiend's Avatar
When my ignition module went out the car wouldn't start at all
Old Mar 26, 2013 | 05:24 AM
Hughes07's Avatar
Yeah it was the switch, cheers
kevpple
Nov 14, 2010 04:05 PM
carve
Sep 12, 2009 09:35 PM
91hatch757
Sep 20, 2005 08:48 AM
JToolz
Feb 15, 2004 06:56 PM
