1997 Honda Civic EX - Headlight Problem
Old Mar 20, 2013 | 12:43 PM
TOP91's Avatar
Default 1997 Honda Civic EX - Headlight Problem
Just wanted to know if anybody has any advice before I got out and start trying to fix this. I was pulling in one night and when I flipped my highbeams off my lowbeams came on went dim for about 5 seconds and then died. Toggled the lights on and off and what not, they came on maybe once and never came back on again. That was months ago.
Talked to a couple people and they all said it was the switch on the steering column/ had same problem. I checked the fuses and they were ok. I switched a couple relays around to see if one was bad, didn't do anything. I might try and put an old bulb in if I can't find one and see if one comes on. If not then I guess it's in the wiring somewhere?
Old Mar 20, 2013 | 02:06 PM
TOP91's Avatar
Default Re: 1997 Honda Civic EX - Headlight Problem
I would like to wire it up so that the high beams and low beams come on at the same time anyways when the high beams are on. So since I'm trying to fix that I might as well.
Then again, the housing is plastic not glass..., might not be a good idea :D
abusedvtec
Feb 24, 2011 05:49 AM
tei344
Mar 7, 2008 05:36 PM
Zensei
Feb 29, 2008 08:29 AM
mlong01
Audio / Security / Video
Jul 17, 2007 05:30 PM
