Rough idle 500 rpms or below! Help.
Old Mar 15, 2013 | 09:43 AM
Hyde1's Avatar
Default Rough idle 500 rpms or below! Help.
Okay so i had this problem for a while and since i had it i threw on the new spark plugs and it helped for a couple minutes then went back to the rough idle. I changed the fuel filter and nothing. This only happens when the engine is warm. in the morning at a cold start it idles at 1500 rpms and sounds like it starts to back fire and slowly goes down to 1000 rpms. as i drive and it gets warm then the idle goes to 500 rpms. I don't know what is wrong. I also looked at it today and unpluged one of the vacuum hoses connected to the fuel rail and that made the rough idle go away. I then connected it back and the rough idle hit even harder. If i leave the hose disconnected it idles fine but when i drive with it disconnected it makes my car surge(vacuum leak) when i come to a stop but then goes away after 25 seconds. thats only when i have the hose disconnected. when its connected i drive and come to a stop it doesnt surge but it idles rough. Can someone tell me what might cause this?
Pics.
Thats the vacuum hose i was talking about.
Old Mar 15, 2013 | 10:52 AM
EFfin Sedan 91's Avatar
Default Re: Rough idle 500 rpms or below! Help.
I would start by cleaning out the IACV, FITV, and replacing the throttle body gasket. That seemed to solve the problem for me. The gasket is ~3 dollars and cleaning the sensors just takes some time and some throttle body/carb cleaner.
Old Mar 15, 2013 | 10:58 AM
mitchh29's Avatar
That hose is connected to the fuel pressure regulator. Mine is currently disconnected and im planning on fixing that. Im thinking thats whats causing mine to have a low idle. Leave it connected.
Old Mar 15, 2013 | 11:29 AM
Hyde1's Avatar
I'll try to clean it tomorrow since i have work in a bit. and try a new gasket aswell. Thanks! But for the carb cleaner what would i spray it on? the throttle body? I also replaced the IACV but what kind of valve is a FITV?
Old Mar 15, 2013 | 11:30 AM
Hyde1's Avatar
Is the problem the fuel pressure regulator then?
Old Mar 15, 2013 | 11:31 AM
_Smartin_'s Avatar
Could also be air in the cooling system if you've messed w that recently. Try burping the system too.
Old Mar 15, 2013 | 11:56 AM
mitchh29's Avatar
It could be. Ill pm you when i replace mine and Let you know
Old Mar 19, 2013 | 11:32 AM
Hyde1's Avatar
Well i haven't messed with the cooling system besides refilling the coolant tank. and burping the system? how would i do that?
Old Mar 19, 2013 | 11:33 AM
Hyde1's Avatar
Okay thanks i appreciate it!
Old Mar 19, 2013 | 12:33 PM
Emeraldbomber's Avatar
Either fitv or iacv need cleaning. The coolant may need to be bled. Throttle may need cleaning. If that FPR is dieing or bad it will make a crappy idle.
Old Mar 20, 2013 | 05:38 AM
Hyde1's Avatar
fitv? and i changed the iacv a while ago from a junked civic but it seems like that one was way better then mine anyways. and i might clean the throttle body tomorrow but i figured it is the FPR that needs to be replaced but autozone sells them for around $80 -. - might buy this used one i found on ebay for $20 because it looks a lot cleaner than mine.
Old Mar 20, 2013 | 12:30 PM
Project97EX's Avatar
I'm sure you have tried this but in case you haven't. Disconnect the IACV adjust the idle screw and reconnect it. That helped my idle. At first i forgot to disconnect the IACV and it didn't really do much.
Old Mar 20, 2013 | 04:54 PM
Hyde1's Avatar
No i havent tried that! thanks! do you know if theres a diagram or video i could look at to see what im working with? thanks !
Old Mar 20, 2013 | 07:13 PM
This might help. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/adjusting-idle-3041878/
There is another link on adjusting the FITV too https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-fix-your-idleing-woes-fitv-iacv-2153910/
hopefully that helps
Old Mar 20, 2013 | 07:16 PM
FITV= Fast Idle Thermal Valve
Old Mar 21, 2013 | 12:21 PM
hmoobvwj's Avatar
My car was like that and all it took mine lucky was just adjusting the idle screw.
Old Mar 22, 2013 | 05:35 AM
Hyde1's Avatar
This might help. https://honda-tech.com/forums/showthread.php?t=3041878
There is another link on adjusting the FITV too https://honda-tech.com/forums/showthread.php?t=2153910
Thanks! this did help a bit but it still idles a little rough :/ so im guessing its the FPR.
Thanks!
Old Mar 22, 2013 | 09:19 AM
Is the Check Engine light on? If so, what codes are coming up?
Old Mar 22, 2013 | 11:26 AM
Hyde1's Avatar
It was on and it gave the Primary Oxygen Sensor code, i replaced the o2 sensor and that cleared the light. but my rough idle was even before the cel
Old Apr 2, 2013 | 05:39 AM
Hyde1's Avatar
Bump, still havent found a solution :/ and now my car surges when it starts and last for about a minute then goes away. i think that might be caused by the iacv sensor
Old Apr 2, 2013 | 07:31 AM
Bighun318's Avatar
yes but did you clean it with carb cleaner???
Old Apr 3, 2013 | 08:54 AM
ERHonda15's Avatar
Posted from Honda-tech.com App for Android
Old Apr 3, 2013 | 09:07 AM
mitchh29's Avatar
Hey Hyde so when I replaced my fuel pressure regulator it seemed to help exponentially. I had to do some tinkering with another vacuum line to get the idle just right though. Im pretty sure we don't have the same intake Mani though so it might even out for you with just a new fuel pressure regulator hooked up.
Old Apr 8, 2013 | 06:10 AM
Did you reset the ecu?
Old Apr 8, 2013 | 09:59 AM
Hyde1's Avatar
No i didnt clean it with car cleaner :/ i might be able to clean it today though.
Oh nice! I can buy a fuel pressure regulator online for about $25 but it's used. should i go for it?
Yes i reset the ECU by removing the fuse for 5 min.
joelmatt89
13
Mar 9, 2009 07:03 AM
bb4 jdm lude
Mar 12, 2008 09:25 AM
efyou
Apr 18, 2007 06:00 PM
EK Josh
29
Apr 11, 2005 11:05 AM
raene
Nov 7, 2002 08:21 PM
