will an obd0 distributor work on an obd1 car?
Old Mar 13, 2013 | 07:09 PM
ryanangelo212's Avatar
Icon2 will an obd0 distributor work on an obd1 car?
building a crx with an ls at the moment, all ready to go except i need a distributor. im all wired obd1 already, but im having a hell of a time finding an obd1 dizzy at a decent price. got an old obd0 ls dizzy laying around though, if i swap the plugs on the harness will it work or is it electronically incompatible with obd1?
Old Mar 13, 2013 | 07:25 PM
RuneRavenX's Avatar
You can wire it to work. Rywire has a harness that allows you to use the obd0 on an obd1 setup
Posted from Honda-tech.com App for Android
Old Mar 13, 2013 | 09:17 PM
ef yu's Avatar
Default Re: will an obd0 distributor work on an obd1 car?
NO it will not work. your ecu and distributor must be of the same OBD.
Old Mar 13, 2013 | 09:34 PM
turfoeg8's Avatar
Your wrong ef yu im running a obd2 distributor in a obd1 chassis with an obd1 ecu, no jerry rigging at all. I got a rywire adapter harness like stated above, ive seen em for either obd
Old Mar 13, 2013 | 10:14 PM
ef yu's Avatar
ok sorry i meant in from obd0 to obd1.
I stand corrected as in a OBD1 ecu + obd0 dizzy will NOT WORK.
Old Mar 13, 2013 | 10:41 PM
Jason Sensation's Avatar
Isn't it something to do with cam angle sensors being built in on obd1 and seperate in obd0?
Old Mar 14, 2013 | 07:27 AM
4drEF's Avatar
Keyboard Humorist
OBD0 and OBD1 distributors are internally different and
NOT compatible.
EF YU, you are correct!
The reluctor wheel inside have different tooth count and ultimately send the ECU different electronic signals.
OBD0 - 16teeth
OBD1 - 24teeth
The jumper harnesses do NOT solve this problem.
They simply allow you to plug in different distributors (to match your ECU) into your existing engine harness.
Old Mar 14, 2013 | 08:09 AM
94EG8's Avatar
Seagull Management
^ Correct
Old Mar 14, 2013 | 08:26 AM
4drEF's Avatar
Keyboard Humorist
OBD2 and OBD1 are compatible.
This thread has nothing to do with OBD2 though so your post is completely irrelevant.
OBD0 and OBD1.
Old Mar 18, 2013 | 12:23 AM
RuneRavenX's Avatar
I read this post completely backwards. The only way that Rywire harness works is if you had an OBD0 chassis and wanted to use an OBD1 Distributor with a matching ECU. You cannot use the OBD0 on an OBD1, they can't be interchanged. That's what I get for being half asleep while posting.
ricardo13d
11
Dec 8, 2011 06:55 PM
Dkahn18
Feb 18, 2009 04:41 PM
crxsteve
Aug 10, 2007 03:15 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
chirp2hrd
May 2, 2003 04:26 PM
