vtec help
Old Mar 13, 2013 | 10:57 AM
mitchh29's Avatar
Default vtec help
The previous owner of my 95 coupe with a b16a swap bypassed the vtec with a wire to run it to a toggle switch on the dash. If i just remove the wire he used to bypass with will the vtec kick in when it is supposed to again?
Old Mar 13, 2013 | 11:02 AM
B_Swapped93's Avatar
Default Re: vtec help
Why on earth did he do that ? The solution:Re-wire it correctly to the ecu/solinoid.
HondaPartsHero's Avatar
Technical Hero
With it seeing how they wired it its impossible to tell. However if they wired it like people normally do it should work. What ECU are you running?
Old Mar 13, 2013 | 11:05 AM
mitchh29's Avatar
Im pretty sure its a P27 ECU. Ill post a picture of the wire in just a minute
Old Mar 13, 2013 | 11:09 AM
mitchh29's Avatar
Here is a picture of the wire that is bypassing the vtec
Old Mar 13, 2013 | 11:11 AM
mitchh29's Avatar
And im pretty sure its still all wired to the ECU because the ECU is looking for the vtec. Its throwing CEL code #22 ( VTEC Malfunction )
Old Mar 13, 2013 | 11:57 AM
mitchh29's Avatar
Based on the picture can anyone tell me if i can just yank the wire and have it go back to normal?
Old Mar 13, 2013 | 12:23 PM
grumblemarc's Avatar
The Grumpiest
Try it. More than likely no.
THEDirtyDseriesWOOT
Jun 13, 2007 06:38 AM
05 S2K Stoner
Oct 28, 2004 06:40 AM
mr. carpenter
May 5, 2004 09:47 PM
