Apexi Turbo Timer, HELP
Old Mar 6, 2013 | 11:34 PM
OklahomaEg's Avatar
Default Apexi Turbo Timer, HELP
Im sure there are threads like this out there, but I couldnt find the info I needed. I have no idea how to install it, If you guys could explain to me which wires go where, I would have no problem soldering the wires, There is a white plug with a red/green/blue wire going into it, and then there is the grey and black that are separate, this is the pen style turbo timer. If you guys know of where I could find a decent write up, or pictures of ignition wiring it would be greatly appreciated. Thanks in advance
Old Mar 7, 2013 | 01:51 PM
fcm's Avatar
fcm
Old Fart
Default Re: Apexi Turbo Timer, HELP
A model number would help.
The ones I have done are...
Red- 12V+ constant, [hot at all times].
Green - ign.1, [hot in run and start]
Blue - ign.2, [hot in run] you may or may not need it. depends on MM&Y of car.
Gray - hand/E-brake.
Black - ground. 94
Old Mar 7, 2013 | 10:37 PM
OklahomaEg's Avatar
Black - ground. 94
Thank you, it is going on an eg hatch, I am not sure of the model number of the unit, it is just a pen style apexi timer.
splickitysplat
Dec 27, 2006 08:17 AM
siis2fast
Jul 3, 2004 10:30 AM
98teg
Oct 8, 2003 01:34 PM
KooK
Sep 10, 2003 06:56 PM
MugenHonda
Nov 4, 2002 12:38 PM
