Help - need help on wiring apexi turbo timer!
Old Oct 6, 2003 | 07:37 PM
98teg's Avatar
Default Help - need help on wiring apexi turbo timer!
Got a free tubo timer from my friend, but he doesn't have the instruction manual anymore, so i don't know what the wires are.
This is not the small slim turbo timer which apexi now sells, it's a small lil box one. The serial # for it is AT2 9711-0390. If anyone has this, could you please tell me what the red, green, black, white and blue wires represent.
thanx
Old Oct 7, 2003 | 05:11 PM
98teg's Avatar
Default Re: Help - need help on wiring apexi turbo timer! (98teg)
ttt
Old Oct 7, 2003 | 06:01 PM
turbotypeR@SPEC's Avatar
25 Year Member
red is constant 12v,green is primary ignition,blue is second ignition or accesory,black is ground,white is o2 signal and gray is parking break
Old Oct 7, 2003 | 08:11 PM
98teg's Avatar
Default Re: Help - need help on wiring apexi turbo timer! (turbotypeR)
thanks for the info, this is greatly appreciated. However, I only have one problem. I'm not sure if one of the wires is white or gray. Does the turbo timer require a connection to the parking brake and the 02.
thanx
Old Oct 7, 2003 | 08:58 PM
twkdCD595's Avatar
parking break is req. connection I thought.
a/f just wont have a reading but the timer should work.
Old Oct 8, 2003 | 03:55 AM
25 Year Member
Default Re: Help - need help on wiring apexi turbo timer! (twkdCD595)
you do not need to hook up o2 or parking break
Old Oct 8, 2003 | 01:34 PM
98teg's Avatar
thanks for the info guys. I guess i try to see if it hooks up to the parking brake then. It looks like a really simple timer that wouldn't require a o2 connection. It' just looks like all it does it count down
fourv2
Jun 24, 2005 04:03 PM
darkirony
Oct 18, 2004 10:18 AM
B18C-RnVA
Dec 16, 2002 01:03 PM
Hybrid
Feb 11, 2002 04:24 PM
