97 Honda civic problems help
Old Mar 3, 2013 | 04:28 PM
DJBLUEB20's Avatar
Icon2 97 Honda civic problems help
My car is an Auto 97 Honda civic and these are the problems I'm having:
I can't change the gears without putting a key in the shift lock to allow for gear shifting.
I bought an OBD2 code scanner and came up with the following codes:
p0112-Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P1298 Electric Load Detector (ELD) Circuit High Voltage
what can you guys suggest for solution's to these problem's?
Old Mar 5, 2013 | 05:37 PM
DJBLUEB20's Avatar
Default Re: 97 Honda civic problems help
BUMP
Old Mar 6, 2013 | 06:42 AM
fcm's Avatar
fcm
Old Fart
Shift-lock solenoid is not getting power or is defective.
Remove console and check for power to shift-lock solenoid with ign. switch on and stepping on brake. 94
Old Mar 8, 2013 | 07:26 PM
DJBLUEB20's Avatar
Icon2 Re: 97 Honda civic problems help
I figured that. Okay, so I'm gonna turn the ignition key to "on" and step on the brake and what is suppose to happen?
Old Mar 10, 2013 | 08:32 AM
fcm's Avatar
fcm
Old Fart
Power is supplied to the shift lock solenoid, #4, it disengages, unlocking the shift lever...
Name:  97 honda civic shift lever.png
Either the circuit is open or solenoid is NG. 94
Gmoney98
Oct 7, 2018 11:06 PM
Doud1977
Nov 23, 2017 02:10 AM
Sfehr
May 12, 2011 03:55 PM
ramo5150
Dec 21, 2006 06:59 AM
