Help with 93 dx hatch rear disc conversion
Old Mar 3, 2013 | 03:58 PM
wolfman93's Avatar
Icon2 Help with 93 dx hatch rear disc conversion
I have the trailing arms off of a del sol si but all the bushings are shot. I read a few places say I can swap the hub to my drum brake trailing arms. Is this true? what e brake cables do I use? Also running the del sol si master cylinder. Should I upgrade it and which proportioning valve? Any help will be appreciated.
Old Mar 5, 2013 | 05:32 PM
Int3graz's Avatar
Default Re: Help with 93 dx hatch rear disc conversion
Try checking in FAQ for brake conversions they have all of this covered although it can be tricky to figure out! Goodluck!
Old Mar 5, 2013 | 10:28 PM
fasterthanueg's Avatar
why dont you replace the bushings they are easy if the trailing arms arent installed yet. and you need a 4040 prop valve integra RS non abs pm me if you have more questions
Old Mar 6, 2013 | 07:43 AM
CPTJDM's Avatar
Energy Suspension bushings are relatively inexpensive and easy to change. I did mine in an afternoon. Many people do not like the squeaking issue usually attributed to poly urethane bushings. I personally have had mine on my car for over a year and don't even notice any squeaking. Though, that may be from my overly loud exhaust.
Old Mar 6, 2013 | 11:42 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Replace the bushings - this is the best solution. Something you should do anyway since the arms are off the car. If you don't want to spring for OEM there are aftermarket rubber ones made. Look on rockauto.com. Prices are affordable.
If you're really cheap ... knock the bushings out of the drum trailing arms and put em on the discs. Not advisable though. You're better off with replacements anyway.
Old Mar 6, 2013 | 11:48 AM
Smurf93's Avatar
IIRC you can use 99 si e brake lines or 94-01 integra e brake lines
Old Mar 6, 2013 | 12:21 PM
wolfman93's Avatar
thanks guys
Old Mar 6, 2013 | 01:28 PM
94EG8's Avatar
Seagull Management
Yes you can swap spindles, but those torx bolts are such a pain in the *** I'd replace the bushings. Also, '92 - '95 Si cables are the perfect fit, you can use the others but if you're buying new you might as well get the right ones.
Old Mar 7, 2013 | 04:30 PM
wolfman93's Avatar
Should I upgrade the MC? I plan on getting the ex/si knuckles too.
Old Mar 7, 2013 | 04:36 PM
Yes but don't change it till you do the bigger fronts
Old Mar 7, 2013 | 04:38 PM
wolfman93's Avatar
ok.thanks man. im still pretty new on this ****
Old Mar 7, 2013 | 06:05 PM
wolfman93's Avatar
thanks man
H23_del_soul
17
Apr 4, 2020 06:34 AM
HairyHarry
12
Jul 9, 2019 11:51 AM
Elijah Trevino
Jun 23, 2018 08:29 PM
wstmsol
Suspension & Brakes
Dec 19, 2011 08:43 PM
d16z6_ej1
Jun 4, 2009 01:29 AM
