Need Help! my car dies when i hit the gas pedal
Old Mar 2, 2013 | 07:36 AM
crx-pr1's Avatar
Icon5 Need Help! my car dies when i hit the gas pedal
Car ( civic 98 ) doesn't want to rev up 3000rpm, if a hit the pedal like almost 2 seconds the motor just dies. Pull out the map and tps same problem just revved higher to 5000rpm , later on day i will try to get ecu code (oem obd2 ecu)If anyone have an idea for whats is the problem I really appreciate.
Old Mar 2, 2013 | 10:32 AM
RoseFuneral's Avatar
Default Re: Need Help! my car dies when i hit the gas pedal
check your ignition timing
Old Mar 2, 2013 | 10:47 AM
Former User's Avatar
Pull the CEL codes. Jot them on a piece of paper.
Reset ECU to clear the codes.
Run engine until CEL remains on.
Pull codes and post them.
Old Mar 3, 2013 | 05:04 PM
crx-pr1's Avatar
I doesnt have any obd2 scanner so i just jump with a cable the blue plug and get the code: 7 , 14, 22, 41, 54... my b20 doesnt have crank sensor yet, and also o2 sensor .. idle are connected but doesnt know which color are the cable ... , thanks!
Old Mar 3, 2013 | 05:19 PM
HondaPartsHero's Avatar
Technical Hero
What ECU are you using? Reset the ECU and see what codes come back and then post them.
Old Mar 4, 2013 | 05:10 AM
crx-pr1's Avatar
Using oem ecu 98 civic (i reset it ) if a plug harness +p06 chipped codes: 14 , 22
Old Mar 4, 2013 | 05:23 AM
Technical Hero
There are at least 3 OEM 98 ECUs: P2P (D16Y8), P2E (D16Y7) and P2N (D16Y5), none of which will run a B20 properly. You need an OBD2a PHK ECU from a CRV or at least a P75 from an OBD2a Integra. Code 22 is a vtec code so you shouldn't be throwing that on the P06 ECU unless it has something to do with the chip. For the code 14 you'll have to do a 3 to 2 wire IACV fix if you haven't done so.
Old Mar 4, 2013 | 05:57 AM
crx-pr1's Avatar
My car is civic EX, Iacv fix, which plug is it? I have an unplugged one which have 3 cables, is nothe speedmeter or tps and map, what i have to do with it?
Old Mar 19, 2013 | 03:18 AM
crx-pr1's Avatar
ECU obd1 new chip and dynoed and all problems are gone 127whp 121TQ just header and intake . oem exhaust ....
radicaled434
Aug 16, 2012 07:02 AM
Lou845
Jul 11, 2012 02:53 PM
jesiaczek
Jan 26, 2012 03:31 PM
crvtt96
Jun 6, 2004 04:00 PM
3rdGteg
Oct 18, 2002 08:48 PM
