Sohc 96 civic dx upgrade advice
Old Feb 28, 2013 | 04:14 PM
docmartin1020's Avatar
Default Sohc 96 civic dx upgrade advice
I have a 1996 honda civic dx 4 dr sohc. I want to add a little more power to it. I already added an intake not the short ram either. I am going to add full exhaust with 4-2-1 header. I would like to know what else I would need if I add a new intake and tb to it. Any info would be great. Also Remember I am just trying to add a little bit of kick to the car. so anything else you have in mind would be great . Thanks
Old Feb 28, 2013 | 05:47 PM
slowDB7's Avatar
Default Re: Sohc 96 civic dx upgrade advice
you could always swap a ex trans to make it alittle quicker.
get rid of your y7 intake manifold, it sucks , get the y8 manifold
or do a mini me swap
theres not much else without doing internal work
Old Feb 28, 2013 | 06:15 PM
PaintedCanvas's Avatar
Not necessary, you could always add an B18 throttle body to open up the air flow a bit more. Consider changing the 02 sensor, may help with air/fuel ratio. Going with smaller rims maybe 13's or 14's to help with acceleration.
Hope I cud help. Go SOHC.
Old Feb 28, 2013 | 10:05 PM
Well I was thinking of buying either and edelbrock intake or skunk2 and a new tb. If I do this will i need to upgrade fuel system. I was also thinking of doing the head swap to add the vtec u know the y8 head. My pops has a mill and we could take it down a little for more compression. also what about a cam change. See the thing is i wanna keep the sohc I'm not out to race anyone just want to add a little hp to the car with bolt on mods....
Old Feb 28, 2013 | 10:08 PM
If i get a y8 mani it will just bold right on. and do i use the y8 tb or my y7 tb..
Old Mar 1, 2013 | 05:52 AM
GhostAccord's Avatar
Are you thinking about chipping an ECU or upgrading your engine management system? This is the engine management and tuning section after all.
You could try the Civic section, You would probably get more answers and opinions from there. It contains a lot more specific information about bolt-ons and swaps for your car.
Old Mar 1, 2013 | 09:51 AM
grumblemarc's Avatar
The Grumpiest
Don't waste your time. Not even with the over-hyped mini-me swap.
Do a full engine swap or boost it.
Why is this question plastered all over the forums?
Old Mar 1, 2013 | 04:38 PM
Salami's Avatar
****** noobs.
docmartin1020
Mar 1, 2013 04:31 PM
docmartin1020
Mar 1, 2013 08:41 AM
KuunLB
Feb 3, 2004 02:59 PM
Shadow Templar
Dec 22, 2003 08:52 PM
5thgen
Jan 10, 2002 11:49 PM
