1.5 sohc and a 1.6 sohc. intake manifolds
Will the multi port fuel injected intake manifold from the 1.6l engine fit onto the 1.5 without major modifications? if so does it require a ECM swap?
i know the MPFI has better fuel efficiency and im wanting to get more miles per tank outta my car.
i've got an 89 hatch 5spd with a 1.5l sohc no mods
Re: 1.5 sohc and a 1.6 sohc. intake manifolds (KuunLB)
if you have no internal mods it will be pointless save yourself time and money
the motor is a vacum it only suck so much air putting a larger bore throtle body
will help throtle response but too much work for little profit get a good air filter
for better gas mileage
1 Post
the manifold will fit,but it will require wiring your car for multi-point injection,along with the proper ECU.http://tech.hybridgarage.com/t...g.htm this will give you an idea of the wiring.
if your main concern is fuel mileage,i'd leave it alone.i don't think you'll gain any mileage with the multi-point,and if you do,it won't be enough to justify the work and cost.
chris
chris
jmucivicsi
09-09-2007 08:16 PM
mr twig
47
05-26-2005 11:21 AM
ExospeedAMcrx
36
07-26-2003 08:43 AM
