obd2b gsr swap/obd2b p72 ecu into obd2a 96 civic - Wire harness help!!
Old Feb 28, 2013 | 05:35 AM
Civ-dx-96's Avatar
Default obd2b gsr swap/obd2b p72 ecu into obd2a 96 civic - Wire harness help!!
Ok so im doing a gsr obd2b swap with p72 ecu obd2b into a 96 civic coupe obd2a. My issue Is I am in the middle of a wire harness purchase.
I've been doing research on the swap as much as possible but I'm still in the dark here.
I thought I needed the 99-00 civic ex vtech harness, BUT my seller is saying I need the 96-98 ex vtech harness.
He has both but now I'm not sure what exact one I need. Can someone please help!!
If there's anything that didn't make sense please let me know thanks guys!
Old Feb 28, 2013 | 07:29 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: Wire harness help!!
you need to stay OBD2A for harnesses if that is what the car is. get an obd2a to obd2b jumper for the ECU.
Old Feb 28, 2013 | 07:50 AM
Civ-dx-96's Avatar
Yeah the cAr is obd2a. But it sounds like it would be easier to use obd2a ecu. So would it go smoothly for the following:
Obd2b b18c1 engine
Obd2a ecu
Obd2a wire harness
Obd2a car
Old Feb 28, 2013 | 07:54 AM
doctorake's Avatar
Community Builder
I think that would work, I am unsure of the GSR ECUs though but it sounds fine, I think there may also be some wiring to do with your existing harness
Old Feb 28, 2013 | 07:55 AM
HondaPartsHero's Avatar
Technical Hero
If your ECU is a USDM P72 it's going to have an immobilizer. If its JDM it won't be able to connect with a code scanner. So id go with an OBD2A P72. You have a few options with the wire harness. You can use your harness and add the necessary wiring (VTEC, knock, IABs, IACV rewire, extend secondary 02). Or you can use the 96-98 EX but you'll have to manually add in the secondary 02 and the IABs.
Old Feb 28, 2013 | 07:58 AM
doctorake's Avatar
Community Builder
do all obd2b gsr ECUs have immobilizers? Also I hear there is a way to disable them?
Old Feb 28, 2013 | 08:04 AM
Technical Hero
http://ff-squad.com/ecu2/?page_id=76
Old Feb 28, 2013 | 09:32 AM
Civ-dx-96's Avatar
Default Re: obd2b gsr swap/obd2b p72 ecu into obd2a 96 civic - Wire harness help!!
I see what you guys are taking about it seems more beneficial to do the 2nd option on the link that was posted cuz no cel and no other issues just I couldn't identify a clear solution on how to fix the problem
Old Feb 28, 2013 | 09:38 AM
Civ-dx-96's Avatar
I'm going to get the 96-98 vtech harness and just manually add the secondary o2 and IABs.
As far as the ecu goes I'm going to get the usdm p72 and work on removing the IMM. Hopefully all will go well I'm sure il be posting more problem threads as time progresses lol
Old Feb 28, 2013 | 12:02 PM
Technical Hero
If you get the 96-99 Integra P72 you won't have the IMM issue at all plus you won't have to buy an adapter harness from OBD2A to OBD2B, it'll plug and play.
Old Feb 28, 2013 | 04:15 PM
canadaek's Avatar
this ^ and vtec not vtech
Casey Holt
May 31, 2015 05:32 PM
TK_209
Oct 8, 2009 12:38 PM
kihun_cha
Dec 14, 2005 12:23 PM
ITR.#1446
Sep 10, 2005 04:43 PM
1.8
13
Dec 28, 2004 10:32 AM
