TURBO ?'s..???
ok i bought a used T3/T4hybrid turbo...i was told its a Turbonetics...but wasn't told the trim size...or anything about the turbo...anyone have any suggestions??
i wanna run 20psi after i build my motor this winter....and i have no idea how big the turbo is...and if it will handle 20psi?????????
i plan on sleeving,pistons,rods,head gasket,some head work,hondata,720cc injectors,turbo cams,ACT stage 4 clutch w/flywheel,and intake manifold of some sort...all on my B18B...any tips on what to do...or anymore on my setup???
tips: none. sounds good.
The side of each housing should have an AR reading. Like .70 AR or .50 AR. Also the inlet of the compressor housing has a number inside there as well. Just get those numbers and post and maybe someone can tell you.
does it still have the garrett pn and serial number plate on the center section?
if so please post the pn# here, if its still the garrett tag, i should be able to give you complete info on it.
as far as the compressor housing size, the a/r shoud be stamped on the inside of the outlet.
the turbine housing should have an a/r stamped on the inlet.
hope this helps.
hope this helps.
i'm just curious (post whoring). But what the hell are you gonna to with 20 psi.
I mean 12 psi on a b18 is pretty effin quick IMO. Or are you just shooting for E.T.'s.
BTW. Here's hoping you hit 2bar
(intentionally that is)
i ran 14psi on B18B...gotta go more...i'm shootin for low 11's
gotta beat that supercharged cobra that beat me last year(3 car lengths)
B18C GSR CIVIC
Sep 14, 2005 06:33 PM
hondahatch741
May 30, 2005 12:36 PM
