TURBO ?'s..???
Old Oct 21, 2002 | 04:01 PM
its WANG yoO's Avatar
Default TURBO ?'s..???
ok i bought a used T3/T4hybrid turbo...i was told its a Turbonetics...but wasn't told the trim size...or anything about the turbo...anyone have any suggestions??
i wanna run 20psi after i build my motor this winter....and i have no idea how big the turbo is...and if it will handle 20psi?????????
i plan on sleeving,pistons,rods,head gasket,some head work,hondata,720cc injectors,turbo cams,ACT stage 4 clutch w/flywheel,and intake manifold of some sort...all on my B18B...any tips on what to do...or anymore on my setup???
Old Oct 21, 2002 | 04:48 PM
Default Re: TURBO ?'s..??? (hybridRhatch)
ttt
Old Oct 21, 2002 | 04:54 PM
sutrusu's Avatar
suggestions: when buying a turbo, find out stuff about it.
tips: none. sounds good.
Old Oct 21, 2002 | 06:00 PM
IntegD's Avatar
New User
Default Re: TURBO ?'s..??? (sutrusu)
The side of each housing should have an AR reading. Like .70 AR or .50 AR. Also the inlet of the compressor housing has a number inside there as well. Just get those numbers and post and maybe someone can tell you.
Old Oct 21, 2002 | 06:22 PM
ion_four's Avatar
Default Re: TURBO ?'s..??? (IntegD)
if it's a t3/t4 and it's a b18, you will be able to run 20psi
Old Oct 21, 2002 | 08:46 PM
Default Re: TURBO ?'s..??? (ion_four)
52T-156 exhaust side
53T-001 compressor side
Old Oct 21, 2002 | 08:53 PM
PeakBoost's Avatar
B*A*N*N*E*D
does it still have the garrett pn and serial number plate on the center section?
if so please post the pn# here, if its still the garrett tag, i should be able to give you complete info on it.
as far as the compressor housing size, the a/r shoud be stamped on the inside of the outlet.
the turbine housing should have an a/r stamped on the inlet.
hope this helps.
Old Oct 21, 2002 | 09:11 PM
thats the only numbers on the turbo
Old Oct 21, 2002 | 09:20 PM
T-sohctec's Avatar
i'm just curious (post whoring). But what the hell are you gonna to with 20 psi.
I mean 12 psi on a b18 is pretty effin quick IMO. Or are you just shooting for E.T.'s.
BTW. Here's hoping you hit 2bar
(intentionally that is)
Old Oct 21, 2002 | 09:33 PM
Default Re: TURBO ?'s..??? (T-sohctec)
i ran 14psi on B18B...gotta go more...i'm shootin for low 11's
gotta beat that supercharged cobra that beat me last year(3 car lengths)
Old Oct 21, 2002 | 09:36 PM
roydogg's Avatar
I wanna be just like U
devney
Mar 24, 2010 11:04 AM
chocolatesk8er10
Oct 11, 2008 10:21 PM
B18C GSR CIVIC
Sep 14, 2005 06:33 PM
hondahatch741
May 30, 2005 12:36 PM
